[mapserver-users] label issues...
Worth Lutz
wal3 at mindspring.com
Mon Mar 18 14:00:34 PDT 2013
No the label block goes into your original class block.
LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
EXTENT -143.210462 39.001401 -50.461045 85.911094
DATA '../data/mjcities.shp'
METADATA
'ows_title' 'mjcities'
END
STATUS default
MAXSCALE 1000000
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "circle"
SIZE 15.0
OUTLINECOLOR 0 0 0
COLOR 182 109 194
LABEL
COLOR 255 255 255
FONT "arial"
TYPE "truetype"
SIZE 10
ANGLE 0
POSITION cc
FORCE false
PARTIALS false
END
END
_____
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Mirrlees
Sent: Monday, March 18, 2013 4:21 PM
To: david.fawcett at state.mn.us; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] label issues...
Ok so if I understand this is what it should look like? (stuff thats been
added is in red) Please correct this if i'm wrong as I am still having a bit
of problems...
LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
METADATA
END
STATUS default
MAXSCALE 1000000
TRANSPARENCY 100
CLASS
LABEL
COLOR 255 255 255
FONT "arial"
TYPE "truetype"
SIZE 10
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "circle"
SIZE 15.0
OUTLINECOLOR 0 0 0
COLOR 182 109 194
END
_____
To: mmirrlees at hotmail.com; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] label issues...
Date: Mon, 18 Mar 2013 20:05:55 +0000
You want to create a class in your layer and place it there.
http://mapserver.org/mapfile/class.html
Like this:
MAP
LAYER
CLASS
LABEL
END # end of label
END # end of class
END #end of layer
END #end of map
From: Mark Mirrlees [mailto:mmirrlees at hotmail.com]
Sent: Monday, March 18, 2013 3:00 PM
To: Fawcett, David (MNIT); mapserver-users at lists.osgeo.org
Ok so I want to stick this code into the .map file... where should it be
placed in the section that i bolded?
LABEL
COLOR 255 255 255
FONT "arial"
TYPE "truetype"
SIZE 10
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
Thanks,
Mark
_____
Date: Mon, 18 Mar 2013 19:51:42 +0000
Mark,
You will want to add a LABEL block to your mapfile.
http://mapserver.org/mapfile/label.html
I would also comment out the maxscale until you get the labels working.
David.
Sent: Monday, March 18, 2013 2:48 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] label issues...
Hi all,
Ok so now I have a new problem with the labeling.
I would like to get my labels to start showing up at a scale of 1:1000000
but nothing is working...
here is a snippet of my mapfile...
LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
METADATA
END
STATUS default
MAXSCALE 1000000
TRANSPARENCY 100
CLASSITEM 'NAME'
LABELITEM 'NAME'
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "circle"
SIZE 15.0
OUTLINECOLOR 0 0 0
COLOR 182 109 194
END
Thanks,
Mark
_____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2904 / Virus Database: 2641/6184 - Release Date: 03/17/13
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130318/c1ecf05f/attachment-0001.html>
