[mapserver-users] mapcache returns error 400 bad request
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Mar 19 13:21:19 PDT 2013
This is one of mine:
<source name="tiger2011" type="wms">
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<MAP_IMAGETYPE>agg_qn</MAP_IMAGETYPE>
<LAYERS>Tiger_2011</LAYERS>
<MAP>/u/data/tiger2011-maps/tiger2011-mc.map</MAP>
</params>
</getmap>
<http>
<url>http://localhost/cgi-bin/mapserv-60</url>
</http>
</source>
Here is an OpenLayers app pulling tiles:
http://imaptools.com:8080/demo/tiger-demo2.html
This is what a tile request looks like:
http://imaptools.com:8080/mapcache/?LAYERS=tiger-base&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fjpeg&SRS=EPSG%3A900913&BBOX=-10018754.171394,-2504688.5428484,-7514065.6285457,2.4121254682541e-7&WIDTH=256&HEIGHT=256
Note that this is using the Google Spherical Mercator projection.
-Steve
On 3/19/2013 2:35 PM, Icadedt wrote:
> Stephen,
> do you have an explicit example, please?
> Does it mean i have to do apache url rewriting?
> my mapcache source tag is it correct? :
> <source name="monserv" type="wms">
> <http>
> <url>http://localhost/cgi-bin/mapserv?</url>
> </http>
> <getmap>
> <params>
> <LAYERS>dep_point_pop</LAYERS>
> <MAP>/var/www/mapfile/dep_point.map</MAP>
> </params>
> </getmap>
> </source>
> *De :* Stephen Woodbridge <woodbri at swoodbridge.com>
> *À :* mapserver-users at lists.osgeo.org
> *Envoyé le :* Mardi 19 mars 2013 18h34
> *Objet :* Re: [mapserver-users] mapcache returns error 400 bad request
> The point that Thomas is making is that mapcache understands WMS
> requests NOT mapserver cgi requests
> http://localhost/mapcache?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&layers=test&mode=map&map_imagetype=png&mapext=-135+0+-90+45&imgext=-135+0+-90+45&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
> This does not work because it is not a valid WMS request.
> If you go to the demo page for the WMS service, and view source, then
> you can see how to setup a OpenLayers to talk to mapcache.
> In FF, if you right click on the map, and select view image, you will
> see what the url for the image or tile looks like.
> -Steve W
> On 3/19/2013 1:08 PM, Icadedt wrote:
> > HI,
> > http://localhost/mapcache/demo works great, all the links inside work
> > great to.
> > even if i put out "mode=map" , i have the same error 400 'bad request'
> > you said "make sure your mapserv+mapfile are configured for WMS access",
> > how to check this?
> > *De :* thomas bonfort <thomas.bonfort at gmail.com
> <mailto:thomas.bonfort at gmail.com>>
> > *À :* Icadedt <icadedt at yahoo.fr <mailto:icadedt at yahoo.fr>>
> > *Cc :* "mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>"
> <mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>>
> > *Envoyé le :* Mardi 19 mars 2013 17h08
> > mapcache doesn't understand any "mode=map" mapserver queries, only WMS.
> > - make sure your mapserv+mapfile are configured for WMS access.
> > - test your mapcache service by going to http://server/mapcache/demo
> > thomas
> > On 19 March 2013 16:55, Icadedt <icadedt at yahoo.fr
> > <mailto:icadedt at yahoo.fr <mailto:icadedt at yahoo.fr>>> wrote:
> > > hi ,
> > > when i test this url:
> > > i get the error 400 'bad request' ?
> > > my layer called 'test' comes from mapcache tileset.
> > > when i test my url without mapcache it works great:
> http://localhost/cgi-bin/mapserv?map=/var/www/mapfile/dep_point.map&layers=dep_point_pop&mode=map&map_imagetype=png&mapext=135+0+180+45&imgext=135+0+180+45&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
> > > Here is my mapcache.xml:
> > > <?xml version="1.0" encoding="UTF-8"?>
> > > <!-- see the accompanying mapcache.xml.sample for a fully commented
> > > configuration file -->
> > > <mapcache>
> > > <cache name="disk" type="disk">
> > > <base>/tmp</base>
> > > <symlink_blank/>
> > > </cache>
> > > <http>
> > > </http>
> > > <getmap>
> > > <params>
> > > </params>
> > > </getmap>
> > > </source>
> > > <tileset name="test">
> > > <source>monserv</source>
> > > <cache>disk</cache>
> > > <grid>WGS84</grid>
> > > <grid>g</grid>
> > > <format>PNG</format>
> > > <metatile>5 5</metatile>
> > > <metabuffer>10</metabuffer>
> > > <expires>3600</expires>
> > > </tileset>
> > > <default_format>JPEG</default_format>
> > > <service type="wms" enabled="true">
> > > <full_wms>assemble</full_wms>
> > > <resample_mode>bilinear</resample_mode>
> > > <format>JPEG</format>
> > > <maxsize>4096</maxsize>
> > > </service>
> > > <service type="wmts" enabled="true"/>
> > > <service type="tms" enabled="true"/>
> > > <service type="kml" enabled="true"/>
> > > <service type="gmaps" enabled="true"/>
> > > <service type="ve" enabled="true"/>
> > > <service type="demo" enabled="true"/>
> > > <errors>report</errors>
> > > <lock_dir>/tmp</lock_dir>
> > > </mapcache>
> > > this is my getcapabilities :
> > > http://localhost/mapcache?service=wms&request=getcapabilities
> > > returns:
> > > <WMT_MS_Capabilities
> > version="1.1.1"><Service><Name>OGC:WMS</Name><Title>no
> > > title set, add some in metadata</Title><OnlineResource
> xlink:href="http://localhost/mapcache?"/></Service><Capability><Request><GetCapabilities><Format>application/vnd.ogc.wms_xml</Format><DCPType><HTTP><Get><OnlineResource
> xlink:href="http://localhost/mapcache?"/></Get></HTTP></DCPType></GetCapabilities><GetMap><Format>image/png</Format><Format>image/jpeg</Format><DCPType><HTTP><Get><OnlineResource
> xlink:href="http://localhost/mapcache?"/></Get></HTTP></DCPType></GetMap><GetFeatureInfo><Format>text/plain</Format><Format>application/vnd.ogc.gml</Format><DCPType><HTTP><Get><OnlineResource
> xlink:href="http://localhost/mapcache?"/></Get></HTTP></DCPType></GetFeatureInfo></Request><Exceptions><Format>text/plain</Format></Exceptions><VendorSpecificCapabilities><TileSet><SRS>EPSG:4326</SRS><BoundingBox
> > > SRS="EPSG:4326" minx="-180.000000" miny="-90.000000" maxx="180.000000"
> > > maxy="90.000000"/><Resolutions>0.70312500000000000000
> > 0.35156250000000000000
> > > 0.17578125000000000000 0.08789062500000000000 0.04394531250000000000
> > > 0.02197265625000000000 0.01098632812500000000 0.00549316406250000000
> > > 0.00274658203125000000 0.00137329101562500000 0.00068664550781250000
> > > 0.00034332275390625000 0.00017166137695312500 0.00008583068847656250
> > > 0.00004291534423828120 0.00002145767211914060 0.00001072883605957030
> > > 0.00000536441802978516
> </Resolutions><Width>256</Width><Height>256</Height><Format>image/png</Format><Layers>test</Layers><Styles/></TileSet></VendorSpecificCapabilities><Layer><Name>rootlayer</Name><Title>no
> metadata</Title><SRS>EPSG:900913</SRS><SRS>EPSG:4326</SRS><SRS>EPSG:3857</SRS><Layer
> > > cascaded="1" queryable="0"><Name>test</Name><LatLonBoundingBox
> > > maxy="90.000000"/><BoundingBox SRS="EPSG:4326" minx="-180.000000"
> > > maxy="90.000000"/><SRS>EPSG:4326</SRS><BoundingBox SRS="EPSG:900913"
> > > minx="-20037508.342789" miny="-20037508.342789" maxx="20037508.342789"
> maxy="20037508.342789"/><SRS>EPSG:900913</SRS><SRS>EPSG:3857</SRS></Layer></Layer></Capability></WMT_MS_Capabilities>
> > > Thanks in advance
> > > _______________________________________________
> > > mapserver-users mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
