[mapserver-users] query problems
Mark Mirrlees
mmirrlees at hotmail.com
Tue Mar 19 15:09:35 PDT 2013
Hey all, One last issue (well for know anyway)... I want to create a basic query so when I open the query I am able to select the major roads and expressways from the mjrroads layer that was created! I have already created the header and footers but not sure where to stick the particular code in the global.map file that contains the headers and footers... Here is my code.# Map file created from QGIS project file C:/wwwroot/M_Mirrlees_Assign3/markassign3.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 500 500
UNITS meters EXTENT -2400000 -900000 3100000 4000000
FONTSET "/wwwroot/fonts/fontset.txt"
SYMBOLSET "/wwwroot/symbols/symbols.sty"
PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_0=49"
"lon_0=-95"
"lat_1=49"
"lat_2=77"
"datum=NAD83"
"units=m"
"no_defs"
END # Background color for the map canvas -- change as desired
IMAGECOLOR 0 100 250
IMAGEQUALITY 95
IMAGETYPE agg OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END # Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH "/ms4w/tmp/ms_tmp/" # Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL "/ms_tmp/" # WMS server settings
METADATA
'ows_title' 'QGIS-MAP'
'ows_onlineresource' 'localhost.com/cgi-bin/mapserv.exe?map=C:/wwwroot/M_Mirrlees_Assign3/global.map'
'ows_srs' 'EPSG:4326'
END #Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'C:/wwwroot/M_Mirrlees_Assign3/global.html'
END
SCALEBAR
STATUS EMBED
UNITS KILOMETERS
INTERVALS 3
TRANSPARENT TRUE
OUTLINECOLOR 0 0 0
END # End for scalebar
QUERYMAP
STATUS ON # sets the map to be queryable
STYLE HILITE # the selected object is highligthed
END # End for QueryMap
WEB
TEMPLATE global.html
IMAGEURL "/ms_tmp/"
HEADER "/maps/M_Mirrlees_assign3/header.html"
FOOTER "maps/M_Mirrlees_assign3/footer.html"
EMPTY "/maps/M_Mirrlees_Assign3/blank.html"
END #End for WEB LAYER
NAME 'mjrroads'
TYPE LINE
DUMP false
EXTENT -143.210462 39.001401 -50.461045 85.911094
DATA '../data/mjrroads.shp'
METADATA
'ows_title' 'mjrroads'
END
STATUS default
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASSITEM 'TYPE'
CLASS
NAME "default"
EXPRESSION ""
STYLE
WIDTH 0.91
COLOR 201 157 32
END
END
CLASS
NAME "TYPE = Expressway"
EXPRESSION "Expressway"
STYLE
WIDTH 2.0
COLOR 255 0 0
END
END
CLASS
NAME "TYPE = Primary Highway"
EXPRESSION "Primary Highway"
MAXSCALEDENOM 2500000
STYLE
WIDTH 1.0
COLOR 0 0 0
END
END
END I must apologize for all the questions, as i'm still fairly new at this but everyone who has taken the time to help me is quite appreciated as this is making a lot of sense now. Thanks,Mark
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130319/4e7a0a31/attachment-0001.html>
