[mapserver-users] query creation issues
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Mar 20 10:00:47 PDT 2013
Hi Mark: Personally I'd steer you to the simplified query templates as described here:
http://mapserver.org/development/rfc/ms-rfc-36.html
This allows you to put everything in one place and better separates data from presentation. No more header/footer's. Plus you can have multiple presentations for the same layer.
That said, the mapfile below doesn't have any queryable layers. There is no TEMPLATE defined for the one layer that is present.
If you want to use the new style templating you'd do something like this:
1- Define an output format:
OUTPUTFORMAT
NAME 'my-template'
DRIVER 'TEMPLATE'
MIMETYPE 'text/html; subtype=compass'
FORMATOPTION "FILE=templates/my-template.html"
END
2- Optionally make it the default query format (otherwise you need to use qformat CGI parameter):
WEB
QUERYFORMAT 'my-template'
END
3- Make layers queryable by adding something like:
TEMPLATE 'void'
4- Write your template, for example my-template.html might look like:
--- snip ---
<!-- MapServer Template -->
This is my template:<br/>
[resultset layer="mjrroads"]
[feature]<b>Type</b>: [TYPE][/feature]
[/resultset]
Done presenting layers.
--- snip ---
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Mirrlees
Sent: Wednesday, March 20, 2013 10:45 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] query creation issues
Hello everyone,
I'm trying to create a query so I can query the roads/expressways from the map. I'm pretty sure I have created the headers and footers correctly but not sure...regardless i'm not entirely too sure where to stick the particular code in my .map file (shown below). I have bolded the code that I'm trying to incorporate into the .map file but not sure why it's not working. Thanks Mark
# Map file created from QGIS project file C:/wwwroot/M_Mirrlees_Assign3/markassign3.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 500 500
UNITS meters
EXTENT -2400000 -900000 3100000 4000000
FONTSET "/wwwroot/fonts/fontset.txt"
SYMBOLSET "/wwwroot/symbols/symbols.sty"
PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_0=49"
"lon_0=-95"
"lat_1=49"
"lat_2=77"
"datum=NAD83"
"units=m"
"no_defs"
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 0 100 250
IMAGEQUALITY 95
IMAGETYPE agg
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH "/ms4w/tmp/ms_tmp/"
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL "/ms_tmp/"
# WMS server settings
METADATA
'ows_title' 'QGIS-MAP'
'ows_onlineresource' 'localhost.com/cgi-bin/mapserv.exe?map=C:/wwwroot/M_Mirrlees_Assign3/global.map'
'ows_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'C:/wwwroot/M_Mirrlees_Assign3/global.html'
END
SCALEBAR
STATUS EMBED
UNITS KILOMETERS
INTERVALS 3
TRANSPARENT TRUE
OUTLINECOLOR 0 0 0
END # End for scalebar
QUERYMAP
STATUS ON # sets the map to be queryable
STYLE HILITE # the selected object is highligthed
END # End for QueryMap
WEB
TEMPLATE global.html
IMAGEURL "/ms_tmp/"
HEADER "/maps/M_Mirrlees_assign3/header.html"
FOOTER "maps/M_Mirrlees_assign3/footer.html"
EMPTY "/maps/M_Mirrlees_Assign3/blank.html"
END #End for WEB
LAYER
NAME 'mjrroads'
TYPE LINE
DUMP false
EXTENT -143.210462 39.001401 -50.461045 85.911094
DATA '../data/mjrroads.shp'
METADATA
'ows_title' 'mjrroads'
END
STATUS default
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASSITEM 'TYPE'
CLASS
NAME "default"
EXPRESSION ""
STYLE
WIDTH 0.91
COLOR 201 157 32
END
END
CLASS
NAME "TYPE = Expressway"
EXPRESSION "Expressway"
STYLE
WIDTH 2.0
COLOR 255 0 0
END
END
CLASS
NAME "TYPE = Primary Highway"
EXPRESSION "Primary Highway"
MAXSCALEDENOM 2500000
STYLE
WIDTH 1.0
COLOR 0 0 0
END
END
END
