[mapserver-users] LABELS - changing from single map to tiles and overlays - HOW?
Worth Lutz
wal3 at mindspring.com
Wed Mar 20 10:10:11 PDT 2013
Ok, I'm beginning to understand all the many variables. I have a mapcache
which is turned off at the moment as I was trying to work on styling. For
example, change one thing and redraw. Change it again to figure out what is
going on.
I plan on using mapcache, so if I use metatiles I then use a "gutter/buffer"
around the metatile and that eliminates the clipping on the edges of the
metatile?
I think I'm putting the pieces together now!
Worth
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Wednesday, March 20, 2013 12:59 PM
To: Worth Lutz
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] LABELS - changing from single map to tiles
and overlays - HOW?
On 20 March 2013 17:49, Worth Lutz <wal3 at mindspring.com> wrote:
> I've now got labels on my maps when zoomed out but my polygons have no
> labels if I zoom in away from the label location.
> I'm using:
> PROCESSING "LABEL_NO_CLIP=True"
> Is this a fixable problem?
That's the aim of LABEL_NO_CLIP, i.e. only label a polygon at a single
geographical location to prevent the label from a single polygon
appearing on every tile if that polygon spans multiple tiles.
YMMV, but you might want to remove LABEL_NO_CLIP and use metatiles on
your tile cache (e,g: with a 2x2 metatile, your label would only be
rendered in one of every 4 tiles). If you aren't using a tile cache,
then there's no easy solution I know of.
> Are there any examples of getting labels with mapserver and openlayers
using
> tiles and multiple overlay layers?
If you're using multiple label overlays, there's no way to control
collision between the labels from different layers.
> I'm still experimenting but still confused. Any help would be
appreciated.
> Thanks,
> Worth
> ________________________________
> From: Worth Lutz [mailto:wal3 at mindspring.com]
> Sent: Tuesday, March 19, 2013 3:39 PM
> To: 'Donald Kerr'; 'mapserver-users at lists.osgeo.org'
> Subject: RE: [mapserver-users] LABELS - changing from single map to tiles
> and overlays - HOW?
> Donald,
> How does the change to "TYPE POINT" work for polygon shapes or do you just
> change that to "TYPE POLYGON" and only have a label in the "CLASS" block?
> I'm still confused on how to manage labels on multiple overlay layers.
That
> may be a long term project for my application. I was hoping for a simple
> solution.
> I did figure out that putting
> in my layer fixed some of my problems of multiple labels with many
clipped.
> Thanks for your help,
> Worth
> From: Donald Kerr [mailto:donald.kerr at dkerr.co.uk]
> Sent: Tuesday, March 19, 2013 3:29 PM
> To: 'Worth Lutz'; mapserver-users at lists.osgeo.org
> and overlays - HOW?
> Worth,
> I have replaced "TYPE ANNOTATION" with "TYPE POINT" and all is working
well.
> As for tiling and labels, I have not found a satisfactory solution at all
> and have accepted that I am getting partial labels or no labels it the
label
> starts in another tile - See here:
> https://github.com/mapserver/mapserver/issues/4284
> What I have done is offered an option of "Single Tile" for users so that
> they can switch between tiled and not. The tiled option gives a better
> OpenLayers slippy map experience but the single tile option allows for
> accurate and complete labelling.
> Regards,
> Donald
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Worth Lutz
> Sent: 19 March 2013 14:52
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] LABELS - changing from single map to tiles and
> overlays - HOW?
> Hi all,
> I'm changing my usage of mapserver from a single map image to using
> OpenLayers and having MapServer work as a WMS server.
> My problem is labels. There seem to be too many variables (in MapServer
and
> OpenLayers) and I cannot figure out which to set to keep from having
partial
> labels, too many labels or overlapping labels.
> What is the best way to approach labels in a tiled / overlay environment.
> I noticed that in MapServer 6.0 the "annotation" layer type is deprecated.
> What is the method for replacing this?
> In summary, I'm LOST. Anyone with a map, please point me in the right
> direction. J
> Thanks,
> Worth
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2013.0.2904 / Virus Database: 2641/6188 - Release Date: 03/19/13
Version: 2013.0.2904 / Virus Database: 2641/6189 - Release Date: 03/19/13
