[mapserver-users] CLUSTER - Average Value
thomas bonfort
thomas.bonfort at gmail.com
Fri Mar 22 07:10:43 PDT 2013
Unless the cluster introduced some new codepaths in the rendering
chain, I do not think this is the case. Only a *single* class gets
used per rendered feature (the first one matching all expression and
min/maxscale constraints)
thomas
On 22 March 2013 14:59, Tamas Szekeres <szekerest at gmail.com> wrote:
> I think adding multiple classes to the clustered layer (with multiple
> expressions regarding to the intervals) should do the job.
> Best regards,
> Tamas
> 2013/3/22 Mark Davidson <mark at 4each.co.uk>
>> That works great thanks Tamas. I'm now trying to use that expression as a
>> condition on a class.
>> I'm trying to style the clusters a different colour depending on the
>> calculation of that expression. Can multiple styles be applied to a single
>> cluster point?
>> CLASS
>> NAME "Clustered Point"
>> EXPRESSION ("[Cluster:FeatureCount]" != "1")
>> STYLE
>> SIZE 22
>> SYMBOL "circle"
>> COLOR 255 0 0
>> END
>> LABEL
>> TEXT ([Sum:lowesttemperature]/[Count:lowesttemperature])
>> FONT "arial"
>> TYPE truetype
>> SIZE 8
>> COLOR 255 255 255
>> END
>> END
>> CLASS
>> EXPRESSION (([Sum:lowesttemperature]/[Count:lowesttemperature]) > 1)
>> STYLE
>> SYMBOL "circle"
>> COLOR 0 255 0
>> END
>> END
>> On 22 March 2013 13:15, Tamas Szekeres <szekerest at gmail.com> wrote:
>>> Mark,
>>> I think LABEL level expressions would work in this case. Something like:
>>> LABEL
>>> TEXT ([Sum:itemname]/[Count:itemname])
>>> TYPE TRUETYPE
>>> END
>>> Best regards,
>>> Tamas
>>>> Hi All,
>>>> I'm new to using mapserver and have been implementing a WMS overlay
>>>> using the CLUSTER funcionality got pretty much everything I need working,
>>>> but I can't seem to get an average value of a cluster to use as part of the
>>>> styling and labelling.
>>>> I've tried everything I can think of to try and get it working but am
>>>> having no luck. I thought that since you can do [Max:itemname] and
>>>> [Count:itemname] I would be able to do an equation to work out the average,
>>>> but I just get syntax errors with everything I try and haven't been able to
>>>> find any examples of doing this.
>>>> Could anyone tell me if its possible to do this? And if so provide an
>>>> example?
>>>> Any input would be very much appreciated,
>>>> Thanks,
>>>> Mark Davidson
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
