[mapserver-users] CLUSTER - Average Value
Tamas Szekeres
szekerest at gmail.com
Fri Mar 22 06:59:47 PDT 2013
I think adding multiple classes to the clustered layer (with multiple
expressions regarding to the intervals) should do the job.
Best regards,
Tamas
2013/3/22 Mark Davidson <mark at 4each.co.uk>
> That works great thanks Tamas. I'm now trying to use that expression as a
> condition on a class.
> I'm trying to style the clusters a different colour depending on the
> calculation of that expression. Can multiple styles be applied to a single
> cluster point?
> CLASS
> NAME "Clustered Point"
> EXPRESSION ("[Cluster:FeatureCount]" != "1")
> STYLE
> SIZE 22
> SYMBOL "circle"
> COLOR 255 0 0
> END
> LABEL
> TEXT ([Sum:lowesttemperature]/[Count:lowesttemperature])
> FONT "arial"
> TYPE truetype
> SIZE 8
> COLOR 255 255 255
> END
> END
> CLASS
> EXPRESSION (([Sum:lowesttemperature]/[Count:lowesttemperature]) > 1)
> STYLE
> SYMBOL "circle"
> COLOR 0 255 0
> END
> END
> On 22 March 2013 13:15, Tamas Szekeres <szekerest at gmail.com> wrote:
>> Mark,
>> I think LABEL level expressions would work in this case. Something like:
>> LABEL
>> TEXT ([Sum:itemname]/[Count:itemname])
>> TYPE TRUETYPE
>> END
>> Best regards,
>> Tamas
>>> Hi All,
>>> I'm new to using mapserver and have been implementing a WMS overlay
>>> using the CLUSTER funcionality got pretty much everything I need working,
>>> but I can't seem to get an average value of a cluster to use as part of the
>>> styling and labelling.
>>> I've tried everything I can think of to try and get it working but am
>>> having no luck. I thought that since you can do [Max:itemname] and
>>> [Count:itemname] I would be able to do an equation to work out the average,
>>> but I just get syntax errors with everything I try and haven't been able to
>>> find any examples of doing this.
>>> Could anyone tell me if its possible to do this? And if so provide an
>>> example?
>>> Any input would be very much appreciated,
>>> Thanks,
>>> Mark Davidson
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130322/33b59d5f/attachment.html>
