[mapserver-users] GetFeatureInfo GML
Mark Davidson
mark at 4each.co.uk
Mon Mar 25 06:50:07 PDT 2013
Here is my entire map file just in-case I’ve done something stupid.
MAP
PROJECTION
"init=epsg:4326"
END
FONTSET "fonts.list"
NAME TEST
STATUS ON
SIZE 1000 1000
MAXSIZE 3000
EXTENT -180 -90 180 90
UNITS DD
WEB
METADATA
"ows_enable_request" "*"
"wms_title" "Testing"
"wms_onlineresource" "
http://localhost/cgi-bin/mapserv?map=test2.map&"
"wms_srs" "EPSG:900913"
END
END
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
LAYER
NAME "test"
METADATA
"wms_title" "Test Points" ##required
END
TEMPLATE "blank.html"
TOLERANCE 10
TYPE POINT
CONNECTIONTYPE postgis
CONNECTION ""
DATA "position from datatable"
DEBUG TRUE
CLASS
STYLE
SIZE 10
SYMBOL "circle"
COLOR 255 0 0
END
END
END
END
On 25 March 2013 13:42, Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca>wrote:
> Mark: try (in LAYER) DUMP TRUE? Can you post the layer definition snippet
> from your mapfile?
> From: mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Davidson
> Sent: Monday, March 25, 2013 09:30
> To: Stefan Schantz
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] GetFeatureInfo GML
> Hi Stefan,
> Thanks for the suggestion, I've tried that but still getting the same
> output as before.
> Any other suggestions?
> Thanks again,
> Mark
> On 25 March 2013 11:41, Stefan Schantz <SSchantz at bfs.de> wrote:
> Hi Mark,
> I use gml_include_items 'all'
> Best regards
> Stefan
> Am 25.03.2013 11:44, schrieb Mark Davidson:
> Hi All,
> I'm trying to do a GetFeaureInfo on my layer and return it in GML format.
> The request works fine but I can't seem to get any data to come back apart
> from the point bounds.
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <test_layer>
> <gml:name>Test Points</gml:name>
> <test_feature>
> <gml:boundedBy>
> <gml:Box srsName="EPSG:900913">
> <gml:coordinates>-269220.293738,6545357.533946
> -269220.293738,6545357.533946</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </test_feature>
> <test_feature>
> <gml:boundedBy>
> <gml:coordinates>-253276.741855,6554416.311795
> -253276.741855,6554416.311795</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </test_feature> </test_layer> </msGMLOutput>
> What I would like to be able to do is get the feature id as what happends
> with the plain output
> GetFeatureInfo results:
> Layer 'test'
> Feature 326:
> Feature 327:
> I've set `gml_include_items` to * and `wms_include_item` to * as well but
> still not having any luck.
> Could someone point me in the direction of doing this?
> Many thanks,
> Mark
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130325/7e46cf99/attachment.html>
