[mapserver-users] GetFeatureInfo GML
Stefan Schantz
SSchantz at BfS.de
Mon Mar 25 07:07:26 PDT 2013
Hi Mark,
I show you my layer definition, which works.
As I understand, the bold parameters in the metadata section are missing
in your mapfile...
LAYER
NAME "odl_einstundenmittel"
TYPE POINT
STATUS ON
MINSCALEDENOM 100001
METADATA
WMS_TITLE "blabla"
WMS_ABSTRACT "blabla"
WMS_ENABLE_REQUEST "*"
INCLUDE "../../include/general/standard_extent_germany_4326.map"
*GML_INCLUDE_ITEMS "name,datum,WERT"
GML_name_ALIAS "Station"
GML_datum_ALIAS "Messende"
GML_WERT_ALIAS "Messwert"*
END
TEMPLATE "blank.gml"
INCLUDE "../../include/general/db_mysql_connect_odl_result.map"
DATA "blöbla"
TOLERANCE 6
TOLERANCEUNITS pixels
INCLUDE "../../include/classes/class_odl_rb_nolabel.map"
END
Regards,
Stefan
Am 25.03.2013 14:50, schrieb Mark Davidson:
> Here is my entire map file just in-case I’ve done something stupid.
> MAP
> PROJECTION
> "init=epsg:4326"
> END
> FONTSET "fonts.list"
> NAME TEST
> STATUS ON
> SIZE 1000 1000
> MAXSIZE 3000
> EXTENT -180 -90 180 90
> UNITS DD
> WEB
> METADATA
> "ows_enable_request" "*"
> "wms_title" "Testing"
> "wms_onlineresource"
> "http://localhost/cgi-bin/mapserv?map=test2.map&
> <http://localhost/cgi-bin/mapserv?map=test2.map&>"
> "wms_srs" "EPSG:900913"
> END
> END
> SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> LAYER
> NAME "test"
> METADATA
> "wms_title" "Test Points" ##required
> END
> TEMPLATE "blank.html"
> TOLERANCE 10
> TYPE POINT
> CONNECTIONTYPE postgis
> CONNECTION ""
> DATA "position from datatable"
> DEBUG TRUE
> CLASS
> STYLE
> SIZE 10
> SYMBOL "circle"
> COLOR 255 0 0
> END
> END
> END
> END
> On 25 March 2013 13:42, Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca
> <mailto:Tom.Kralidis at ec.gc.ca>> wrote:
> Mark: try (in LAYER) DUMP TRUE? Can you post the layer definition
> snippet from your mapfile?
> From: mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> [mailto:mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of
> Mark Davidson
> Sent: Monday, March 25, 2013 09:30
> To: Stefan Schantz
> Cc: mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> Subject: Re: [mapserver-users] GetFeatureInfo GML
> Hi Stefan,
> Thanks for the suggestion, I've tried that but still getting the
> same output as before.
> Any other suggestions?
> Thanks again,
> Mark
> On 25 March 2013 11:41, Stefan Schantz <SSchantz at bfs.de
> <mailto:SSchantz at bfs.de>> wrote:
> Hi Mark,
> I use gml_include_items 'all'
> Best regards
> Stefan
> Am 25.03.2013 11 <tel:25.03.2013%2011>:44, schrieb Mark Davidson:
> Hi All,
> I'm trying to do a GetFeaureInfo on my layer and return it in GML
> format. The request works fine but I can't seem to get any data to
> come back apart from the point bounds.
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <test_layer>
> <gml:name>Test Points</gml:name>
> <test_feature>
> <gml:boundedBy>
> <gml:Box srsName="EPSG:900913">
> <gml:coordinates>-269220.293738,6545357.533946
> -269220.293738,6545357.533946</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </test_feature>
> <test_feature>
> <gml:boundedBy>
> <gml:coordinates>-253276.741855,6554416.311795
> -253276.741855,6554416.311795</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </test_feature> </test_layer> </msGMLOutput>
> What I would like to be able to do is get the feature id as what
> happends with the plain output
> GetFeatureInfo results:
> Layer 'test'
> Feature 326:
> Feature 327:
> I've set `gml_include_items` to * and `wms_include_item` to * as
> well but still not having any luck.
> Could someone point me in the direction of doing this?
> Many thanks,
> Mark
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130325/6a044cdd/attachment-0001.html>
