[mapserver-users] [TinyOWS] Unable to open config file
Luca Delucchi
lucadeluge at gmail.com
Fri May 3 05:49:30 PDT 2013
Hi everybody,
I'm just starting to play with TinyOWS for WFS-T. I installed TinyOWS
on a ubuntu server and I'm using mapfile to configure TinyOWS.
If I run "./tinyows --check" from command line it work well
TinyOWS version: 1.0.0
administrator at webcrev3:/usr/lib/cgi-bin$ TinyOWS version: 1.0.0
PostGIS Version: 2.0.1
PostGIS dsn: dbname='gis_os' host=10.100.113.5 port=5432
user='sde' password='sde' sslmode=disable
Output Encoding: UTF-8
Database Encoding: UTF8
Schema dir: /usr/share/tinyows/schema
Display bbox: Yes
Estimated extent: No
Check schema: Yes
Check valid geoms: Yes
Available layers:
- public.sitiwgs84 (4326) -> .sitiwgs84 [RW]
but when I try from web browser it doesn't work and return "Unable to
open config file"
Do you have any advice to help me?
Thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
