[mapserver-users] Is there still a 2GB size limit on shapefiles?
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Wed May 8 21:32:16 PDT 2013
I am not sure either if reading >2GB shapefiles works with the native shp reader on all platforms, but as the ticket says, you should be able to use OGR connection in the mapfile even with your current version. If you use OGR you can also split the shapefile into pieces and read them through the ogr tileindex system which may be faster sometimes.
-Jukka Rahkonen-
Andrea Peri wrote:
> If it don't work you should evalute the option to use spatialite.
> It work well with dataset greater than 2GB .
> I use it with mapserver 6.3dev and gdal 1.10.
2013/5/9 Roger André <randre at gmail.com<mailto:randre at gmail.com>>
Pretty sure I just hit this<http://trac.osgeo.org/mapserver/ticket/3514> problem in my 6.0.3 local stack. I haven't tested it in the current release, but does anyone know for sure that a shapefile with any component larger than 2GB works in 6.2?
Roger
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
