[mapserver-users] [TinyOWS] Unable to open config file
Luca Delucchi
lucadeluge at gmail.com
Thu May 9 03:10:49 PDT 2013
Sorry for boring you, someone can help me with this problem?
On 3 May 2013 14:49, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi everybody,
> I'm just starting to play with TinyOWS for WFS-T. I installed TinyOWS
> on a ubuntu server and I'm using mapfile to configure TinyOWS.
> If I run "./tinyows --check" from command line it work well
> TinyOWS version: 1.0.0
> administrator at webcrev3:/usr/lib/cgi-bin$ TinyOWS version: 1.0.0
> PostGIS Version: 2.0.1
> PostGIS dsn: dbname='gis_os' host=10.100.113.5 port=5432
> user='sde' password='sde' sslmode=disable
> Output Encoding: UTF-8
> Database Encoding: UTF8
> Schema dir: /usr/share/tinyows/schema
> Display bbox: Yes
> Estimated extent: No
> Check schema: Yes
> Check valid geoms: Yes
> Available layers:
> - public.sitiwgs84 (4326) -> .sitiwgs84 [RW]
> but when I try from web browser it doesn't work and return "Unable to
> open config file"
> Do you have any advice to help me?
> Thanks
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
ciao
Luca
www.lucadelu.org
