[mapserver-users] Display of a layer with a HATCH STYLE
Jean Somers
jean.somers at cocopaq.com
Mon May 13 00:41:39 PDT 2013
I want a hatch style for a polygons layer.
I used that code:
CLASS
NAME 'Protection des eaux potables et minérales(AS1)- périmètre
immédiat'
EXPRESSION /^AS1_I$/
STYLE
SYMBOL "hachure"
COLOR 0 0 0
SIZE 10
WIDTH 3
ANGLE 45
PATTERN 20 10 10 10 END
#SYMBOL ./etc/symboles/plu_as1_A.png
END
but it displays nothing.
The code works when used with a standard style, but fails when I use a
hatchsymbol style.
Could you tell me where I fail?
PS: You can find the whole failing code as attachment in the
PLU_SUP_AS_new.map file.
The PLU_SUP_AS_old.map file is working.
Jean Somers - SIG
Communauté de Communes du Pays de Quimperlé (COCOPAQ)
3, rue Eric Tabarly - Kervidanou 4 - 29394 Quimperlé Cedex
Tel : 02.98.35.09.40 (09.49) - Fax : 02.98.35.09.41
e-mail : jean.somers at cocopaq.com
www.cocopaq.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130513/d489ef89/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130513/d489ef89/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130513/d489ef89/attachment-0001.obj>
