[mapserver-users] Mapserver WMS Reprojection
Donald Kerr
donald.kerr at dkerr.co.uk
Sun May 19 12:57:01 PDT 2013
Slight mistake below; the projection definition in the layer is as follows
with "epsg" in lowercase as I am led to believe that it should be so:
"init=epsg:27700"
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald Kerr
Sent: 19 May 2013 20:36
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Mapserver WMS Reprojection
Hi List,
I am trying to reproject a WMS request from 27700 (UK Ordnance Survey) to
900913 (OSM OpenStreetMap) without success. There no issue with the map file
map or layer definitions in terms of serving up the WMS in 27700 but
reprojection seems to fail. There appears to be very little online and I
cannot find a solution; hence this request for help or advice.
Relevant parts of map file (some parts removed):
PROJECTION
"init=epsg:27700"
END
WEB
METADATA
"wms_title" "My WMS"
"wms_onlineresource" "http://localhost/mapserver/mapserv.asp?"
"wms_srs" "EPSG:27700 EPSG:900913"
"wms_enable_request" "*"
"wms_abstract" "My WMS"
"wms_extent" "0 0 670000 1230000"
"wms_feature_info_mime_type" "text/plain"
"wms_feature_info_mime_type" "text/html"
"wms_feature_info_mime_type" "application/vnd.ogc.gml" #
&info_format=application/vnd.ogc.gml
Layer:
METADATA
"wms_title" "CME"
# "wms_srs" "EPSG:27700 EPSG:900913"
"wms_include_items" "all" # No spaces
"gml_include_items" "all" # No spaces
"gml_featureid" "ID"
END
PROJECTION
"init=EPSG:27700"
END # PROJECTION
Openlayers request:
http://maps1/cgi-bin/mapserv.exe?MAP=D:\MyMapFile.map&LAYERS=CME&TRANSPARENT
=TRUE&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3
A900913&BBOX=-484682.60504583,7512726.3043776,-415889.27960147,7547122.96709
97&WIDTH=900&HEIGHT=450
The result is a transparent image with no data showing. :( The same map file
works correctly and serves an image if used with Openlayers and a map on
EPSG 27700 so it's pointing at the reprojection of the BBOX maybe.
What am I doing wrong? Any help greatly appreciated.
Many thanks.
Regards,
Donald
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.3336 / Virus Database: 3162/6338 - Release Date: 05/19/13
