[mapserver-users] Mapserver WMS Reprojection
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Sun May 19 21:52:49 PDT 2013
I do not see obvious error and the 900913 BBOX hit UK somewhere in Scotland so I guess that you have data there. I was thinking that the fake 900913 code is perhaps not included in the EPSG file and you should use EPSG:3785 instead but that case that would propably lead to some error message. Have still a try with 3785, and add DEBUG 5 into your layer setting and see what you get into your MS_ERRORFILE.
-Jukka Rahkonen-
Donald Kerr wrote:
> Slight mistake below; the projection definition in the layer is as follows
> with "epsg" in lowercase as I am led to believe that it should be so:
> "init=epsg:27700"
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald Kerr
Sent: 19 May 2013 20:36
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Mapserver WMS Reprojection
> Hi List,
> I am trying to reproject a WMS request from 27700 (UK Ordnance Survey) to
900913 (OSM OpenStreetMap) without success. There no issue with the map file
map or layer definitions in terms of serving up the WMS in 27700 but
reprojection seems to fail. There appears to be very little online and I
cannot find a solution; hence this request for help or advice.
> Relevant parts of map file (some parts removed):
>PROJECTION
"init=epsg:27700"
END
WEB
METADATA
"wms_title" "My WMS"
"wms_onlineresource" "http://localhost/mapserver/mapserv.asp?"
"wms_srs" "EPSG:27700 EPSG:900913"
"wms_enable_request" "*"
"wms_abstract" "My WMS"
"wms_extent" "0 0 670000 1230000"
"wms_feature_info_mime_type" "text/plain"
"wms_feature_info_mime_type" "text/html"
"wms_feature_info_mime_type" "application/vnd.ogc.gml" #
&info_format=application/vnd.ogc.gml
Layer:
METADATA
"wms_title" "CME"
# "wms_srs" "EPSG:27700 EPSG:900913"
"wms_include_items" "all" # No spaces
"gml_include_items" "all" # No spaces
"gml_featureid" "ID"
END
PROJECTION
"init=EPSG:27700"
END # PROJECTION
> Openlayers request:
> http://maps1/cgi-bin/mapserv.exe?MAP=D:\MyMapFile.map&LAYERS=CME&TRANSPARENT
=TRUE&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3
A900913&BBOX=-484682.60504583,7512726.3043776,-415889.27960147,7547122.96709
97&WIDTH=900&HEIGHT=450
> The result is a transparent image with no data showing. :( The same map file
works correctly and serves an image if used with Openlayers and a map on
EPSG 27700 so it's pointing at the reprojection of the BBOX maybe.
> What am I doing wrong? Any help greatly appreciated.
> Many thanks.
> Regards,
Donald
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.3336 / Virus Database: 3162/6338 - Release Date: 05/19/13
