[mapserver-users] ORACLE_HOME problem when using spawn-fcgi + mapserver
Jackey Cheung
cheung.jackey at gmail.com
Tue May 21 23:37:57 PDT 2013
I'm setting up a nginx + spawn-fcgi + mapserver centos box.I've installed
everything. The web site (nginx) is working, Oracle is working fine and
returning spatial data, shp2img generates pictures from Oracle data well,
and everything just seem working well. Unless I put them all together.
Requesting map image from the box in browser and I get this:
msDrawMap(): Image handling error. Failed to draw layer named 'BLD_BLDG'.
msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
Handlers. Connection failure. Check the connection string. Error: .
I've tried strace and checked the oracle trace log, and found this in the
oracle log:
<msg time='2013-05-22T14:15:00.181+08:00' org_id='oracle' comp_id='clients'
type='UNKNOWN' level='16' host_id='55.gz.rd.mapking.com'
host_addr='127.0.0.1'>
<txt>Unable to find environment variable: ORACLE_HOME
</txt>
</msg>
I've change the mapserver process to use oracle user, and I've then checked
the spawn-fcgi process environment at /proc/ directory and see that there
are variables in it. I've even tried adding ORACLE_HOME variable to
/etc/profile, but still can't get it working.
What is wrong? Or what have I missed?
P.S. I could have post the whole strace log here, but it's too long so if
anyone really need it to get a clue, just give a mail to me.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130522/bc0a23f4/attachment.html>
