[mapserver-users] ORACLE_HOME problem when using spawn-fcgi + mapserver
richard.suematsu at syncadd.com
Wed May 22 05:14:54 PDT 2013
I could be wrong but I believe /etc/profile is only loaded when you spawn a shell. You can try force the issue and set the oracle home in your startup script for nginx and work backwards from there.
Sent from my iPhone
On May 22, 2013, at 1:38 AM, "Jackey Cheung" <cheung.jackey at gmail.com<mailto:cheung.jackey at gmail.com>> wrote:
I'm setting up a nginx + spawn-fcgi + mapserver centos box.I've installed everything. The web site (nginx) is working, Oracle is working fine and returning spatial data, shp2img generates pictures from Oracle data well, and everything just seem working well. Unless I put them all together.
Requesting map image from the box in browser and I get this:
msDrawMap(): Image handling error. Failed to draw layer named 'BLD_BLDG'. msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI Handlers. Connection failure. Check the connection string. Error: .
I've tried strace and checked the oracle trace log, and found this in the oracle log:
<msg time='2013-05-22T14:15:00.181+08:00' org_id='oracle' comp_id='clients'
type='UNKNOWN' level='16' host_id='55.gz.rd.mapking.com<http://55.gz.rd.mapking.com>'
host_addr='127.0.0.1'>
<txt>Unable to find environment variable: ORACLE_HOME
</txt>
</msg>
I've change the mapserver process to use oracle user, and I've then checked the spawn-fcgi process environment at /proc/ directory and see that there are variables in it. I've even tried adding ORACLE_HOME variable to /etc/profile, but still can't get it working.
What is wrong? Or what have I missed?
P.S. I could have post the whole strace log here, but it's too long so if anyone really need it to get a clue, just give a mail to me.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130522/8ad190e6/attachment.html>
