[mapserver-users] STYLEITEM AUTO or similar for other connection types?
Tamas Szekeres
szekerest at gmail.com
Thu May 23 01:39:08 PDT 2013
Assuming the style definition exists in OGR style format or in MapServer
STYLE or CLASS definitions, you can use STYLEITEM "attributename" which
should work with all drivers (not just with OGR)
When using the OGR driver (and not using the MapInfo driver), you should
use OGR_STYLE as the attribute name to have the feature style set up by OGR
automatically. In this case the style attribute should contain OGR style
strings.
Best regards,
Tamas
2013/5/23 Jackey Cheung <cheung.jackey at gmail.com>
> Hi all,
> Just a short question, does the STYLEITEM supported only for OGR?
> Say I have a column that stores OGR style definitions in Oracle. Must I
> use OGR connection type to utilize those styles? I've tried use
> ORACLESPATIAL, but can't seem to use those styles.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130523/9b6e56e5/attachment.html>
