[mapserver-users] How to configure mapserver as a tile server?
Stephen Woodbridge
woodbri at swoodbridge.com
Sun May 26 06:48:32 PDT 2013
For one thing Your mapcache.xml is requesting an image type agg_qn and
that is not defined in your mapfile. It can be defined like:
OUTPUTFORMAT
NAME "agg_qn"
DRIVER "AGG/PNG"
EXTENSION "png"
MIMETYPE "image/png"
IMAGEMODE RGB
FORMATOPTION "INTERLACE=false"
FORMATOPTION "QUANTIZE_NEW=ON"
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
#TRANSPARENT ON
#FORMATOPTION "TRANSPARENT=ON"
END
Have you checked /var/log/apache2/error.log for error messages and
checked your /tmp/ms_tmp/ms_error files?
/tmp/mapcache. is where you will be putting your tiles, this needs to be
read/writable by the apache2 service and it needs to have enough space
for all your tiles. Also I believe you HAVE to make the top level cache
directory so in your case:
mkdir /tmp/mapcache/ms-base
chmod 777 /tmp/mapcache/ms-base
-Steve W
On 5/26/2013 3:14 AM, Hishan Melanga wrote:
> Can you take a look at my mapcache.xml
> <https://docs.google.com/document/d/1yiwhofPOHDtKaFynhXdH0SPbQhojXZGnd5cw9dBNH7A/edit?usp=sharing>
> and my osm-google.map
> <https://docs.google.com/document/d/1jjdKjJ1kxMFRGTJAstAJ5qk8zUo6MWsYLxW827bC2LM/edit?usp=sharing>
> file? I don't know what I have done wrong. It's not producing the tiles.
> On Sun, May 26, 2013 at 9:21 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 5/25/2013 11:08 PM, Hishan Melanga wrote:
> What is the link to access the tiles in web browser if I used
> your .xml
> as the configuration? Is it still
> http://example.com/mapcache/__demo
> <http://example.com/mapcache/demo> or
> something else.
> You would replace example.com <http://example.com> with your host name.
> Also note the blue (+] buttom in the upper right of the demo map
> page, open this is you have multiple services or tilesets defined
> and you can select that one you want to view.
> Here is my demo page that has data for the US and is pulling tiles
> from my mapcache instance.
> http://imaptools.com:8080/__demo/tiger-demo2.html
> <http://imaptools.com:8080/demo/tiger-demo2.html>
> -Steve
> On Sat, May 25, 2013 at 7:47 PM, Stephen Woodbridge
> <mailto:woodbri at swoodbridge.__com
> <mailto:woodbri at swoodbridge.com>>> wrote:
> So the way this works is:
> browser <----> mapcache <----> mapserver_wms
> So look at the demo page if you have mapcache.xml
> configured then
> you should see a simple OpenLayers application that pulls
> tiles from
> mapcache.
> your mapcache.xml needs look something like this. The
> referrences in
> the source block are explicit references to names in my
> mapfile.
> Obviously parameter values need to be change for your
> server and
> mapfile.
> -Steve
> <?xml version="1.0" encoding="UTF-8"?>
> <mapcache>
> <metadata>
> <title>iMaptools mapcache service</title>
> <abstract>Contains various services for iMaptools
> maps</abstract>
> </metadata>
> <cache name="disk" type="disk">
> <base>/u/mapcache</base>
> <symlink_blank/>
> </cache>
> <source name="tiger2011" type="wms">
> <getmap>
> <params>
> <FORMAT>image/png</FORMAT>
> <MAP_IMAGETYPE>agg_qn</MAP_____IMAGETYPE>
> <LAYERS>Tiger_2011</LAYERS>
> <MAP>/u/data/tiger2011-maps/____tiger2011-mc.map</MAP>
> </params>
> </getmap>
> <http>
> <url>http://localhost/cgi-bin/____mapserv-60
> <http://localhost/cgi-bin/__mapserv-60>
> <http://localhost/cgi-bin/mapserv-60>></url>
> </http>
> </source>
> <format name="PNGQ_FAST" type="PNG">
> <compression>fast</____compression>
> <colors>256</colors>
> </format>
> <tileset name="tiger-base">
> <source>tiger2011</source>
> <cache>disk</cache>
> <grid>WGS84</grid>
> <grid>g</grid>
> <format>PNGQ_FAST</format>
> <metatile>5 5</metatile>
> <!-- metabuffer must be the abs() of what is in the
> mapfile -->
> <metabuffer>20</metabuffer>
> <expires>3600</expires>
> </tileset>
> <default_format>PNGQ_FAST</____default_format>
> <service type="wms" enabled="true">
> <full_wms>assemble</full_wms>
> <resample_mode>bilinear</____resample_mode>
> <maxsize>4096</maxsize>
> </service>
> <service type="wmts" enabled="true"/>
> <service type="tms" enabled="true"/>
> <service type="kml" enabled="true"/>
> <service type="gmaps" enabled="true"/>
> <service type="ve" enabled="true"/>
> <service type="demo" enabled="true"/>
> <errors>report</errors>
> <lock_dir>/tmp</lock_dir>
> </mapcache>
> On 5/25/2013 9:47 AM, Hishan Melanga wrote:
> ok. Now I have http://example.com/mapcache/____demo
> <http://example.com/mapcache/__demo>
> <http://example.com/mapcache/demo>> working. But how can I
> get my mapserver's wms connect to it.
> On Sat, May 25, 2013 at 10:42 AM, Hishan Melanga
> <hishanm at gmail.com <mailto:hishanm at gmail.com>
> <mailto:hishanm at gmail.com <mailto:hishanm at gmail.com>>
> <mailto:hishanm at gmail.com <mailto:hishanm at gmail.com>>>> wrote:
> Thanks. I installed mapcahe and started to learn
> about the xml
> configuration file. Reading
> http://mapserver.org/mapcache/____config.html
> <http://mapserver.org/mapcache/__config.html>
> <http://mapserver.org/__mapcache/config.html
> <http://mapserver.org/mapcache/config.html>> as a start. Hope it
> is the
> first thing that I should do.
> On Sat, May 25, 2013 at 8:07 AM, Stephen Woodbridge
> <mailto:woodbri at swoodbridge.__com <mailto:woodbri at swoodbridge.com>>
> <mailto:woodbri at swoodbridge.>____com
> <mailto:woodbri at swoodbridge.com>>>> wrote:
> On 5/24/2013 10:06 PM, Hishan Melanga wrote:
> I have a working mapserver and I can view
> my map using
> http://localhost/cgi-bin/______mapserv?map=/path/to/map&mode=______browse&template=__openlayers&____layers=all
> <http://localhost/cgi-bin/____mapserv?map=/path/to/map&mode=____browse&template=openlayers&____layers=all>
> <http://localhost/cgi-bin/__mapserv?map=/path/to/map&mode=__browse&template=openlayers&__layers=all>>
> <http://localhost/cgi-bin/mapserv?map=/path/to/map&mode=browse&template=openlayers&layers=all>>>.
> Now I want to give out those data to public as
> tiles giving
> a single URL
> such as tile.myserver.org
> <http://tile.myserver.org>
> <http://tile.myserver.org> <http://tile.myserver.org>
> <http://tile.myproxy.org/>. How can I achieve
> this using Mapserver? What is the place to
> start? What
> tutorials I have
> to read? I've read that Mapserver has a
> tile mode
> <http://mapserver.org/output/______tile_mode.html
> <http://mapserver.org/output/____tile_mode.html>
> <http://mapserver.org/output/__tile_mode.html>>
> <http://mapserver.org/output/tile_mode.html>>>>.
> Thanks in advance.
> mapcache it the tile server for mapserver. So
> you will
> want to
> look at that. The basic scenario is this:
> 1. setup mapserver as a WMS server
> 2. build and install mapcache as an apache module
> 3. setup a mapcache.xml to describe you WMS
> server, and
> your cache.
> make sure you configure the demo service
> initially
> for testing
> you can disable it later if you want
> 4. restart apache
> 5. http://example.com/mapcache/______demo
> <http://example.com/mapcache/____demo>
> <http://example.com/mapcache/__demo>>
> <http://example.com/mapcache/demo>>>
> whenever you change your mapcache.xml you need
> to start
> apache
> so it reads your changes.
> -Steve W
> _____________________________________________________
> mapserver-users at lists.osgeo.______org
> <mailto:mapserver-users at lists.
> <mailto:mapserver-users at lists.>____osgeo.org <http://osgeo.org>
> <mailto:mapserver-users at lists.__osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>>>
> http://lists.osgeo.org/______mailman/listinfo/mapserver-______users
> <http://lists.osgeo.org/____mailman/listinfo/mapserver-____users>
> <http://lists.osgeo.org/__mailman/listinfo/mapserver-__users>>
> <http://lists.osgeo.org/mailman/listinfo/mapserver-users>>>
> හිෂාන් මෙලංග | Hishan Melanga
> <http://hishanmelanga.__blogsp__ot.com/
> <http://blogspot.com/>
> <http://hishanmelanga.__blogspot.com/
> <http://hishanmelanga.blogspot.com/>>>
> mapserver-users at lists.osgeo.____org
> mapserver-users at lists.osgeo.__org
> හිෂාන් මෙලංග | Hishan Melanga <http://hishanmelanga.blogspot.com/>
