[mapserver-users] MapCache "missing a service" error
Jackey Cheung
cheung.jackey at gmail.com
Mon May 27 19:12:18 PDT 2013
I'm trying to deploy a MapCache server. It compiles OK, but I can't tell
whether everything is working fine, since I can't see any output from the
server (command line and HTTP response, etc.)
I've write up a config xml as below:
<mapcache>
<cache name="test_cache" type="disk">
<base>/tmp/mapcache</base>
<symlink_blank />
</cache>
<source name="test_lands" type="wms">
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>BLD_BLDG</LAYERS>
</params>
</getmap>
<http>
<url>http://localhost/map/</url>
<headers>
<User-Agent>mapcache</User-Agent>
</headers>
<connection_timeout>30</connection_timeout>
</http>
</source>
<format name="PNG" type ="PNG">
<compression>fast</compression>
</format>
<default_format>PNG</default_format>
<tileset name="test_tileset">
<source>test_lands</source>
<cache>test_cache</cache>
<grid restricted_extent="113.816929 22.135340 114.504470 22.567942">
WGS84
</grid>
<metadata>
<title>test web map.</title>
<abstract>Powered by MapKing.</abstract>
</metadata>
<format>PNG</format>
<metatile>10 10</metatile>
<metabuffer>10</metabuffer>
</tileset>
<service type="wms" enabled="true">
<full_wms>assemble</full_wms>
<resample_mode>bilinear</resample_mode>
<maxsize>4096</maxsize>
</service>
<service type="wmts" enabled="false"/>
<service type="tms" enabled="false"/>
<service type="kml" enabled="false"/>
<service type="gmaps" enabled="false"/>
<service type="ve" enabled="false"/>
<service type="demo" enabled="false"/>
<errors>report</errors>
<lock_dir>/tmp/mapcache/lock</lock_dir>
<threaded_fetching>true</threaded_fetching>
<log_level>info</log_level>
<auto_reload>true</auto_reload>
</mapcache>
I use spawn-fcgi to start the server:
spawn-fcgi -M 666 -s /var/run/mapcache.sock -n -u nginx -g nginx -U nginx
-G nginx -P /var/run/mapcache.pid -- /usr/local/bin/mapcache
The server seems to be running, since it doesn't return to the command
prompt. When I use browser to open "http://192.168.56.101/mapcache/", the
first request (the exact first request to the newly started server process)
returns:
tileset "test_tileset" references grid "
WGS84
", but it is not configured
Then all subsequent requests returns "missing a service" error.
I've tried adding a WGS84 grid to the xml, but that produces duplicate
declaration error. I've also tried using the mapcache.xml from source
package, the same "missing a service" error occurs.
What's wrong?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130528/8a0298b6/attachment.html>
