[mapserver-users] Mapserver 6.2 on RHEL
Stephan Meißl
stephan at meissl.name
Fri May 31 01:39:04 PDT 2013
Hi Jonas,
sure, that's why we have it :)
cu
Stephan
On 05/30/2013 10:47 AM, Nielsen, Jonas Lund wrote:
> Hi Stephan,
> I am in a similar situation to Jeff, but have so far been compiling from source.
> Would it be ok if I tried grabbing your MapServer 6.2 build from the repo as well?
> I'm not sure I will get around to it anytime soon, though, but I will let you know how it works out.
> - Jonas
> -----Oprindelig meddelelse-----
> Fra: Stephan Meißl [mailto:stephan at meissl.name]
> Sendt: 29. maj 2013 13:22
> Til: mapserver-users at lists.osgeo.org
> Emne: Re: [mapserver-users] Mapserver 6.2 on RHEL
> On 05/28/2013 11:28 PM, Jeff Konnen wrote:
>> Hi all,
>> before going down the compile path, I just want to make sure I didn't miss something.
>> I need to install mapserver 6.2 on RHEL 6.4 and was looking for a repository or a rpm.
>> but I couldn't find anything.
>> Is there something out there that I could have missed?
>> Thanks a lot in advance
>> Jeff
> Hi Jeff,
> we're hosting an EL 6 yum repository including MapServer 6.2 builds at
> http://packages.eox.at/ The packages are generated on CentOS hosts but
> should work on RHEL. If you give it a try I'd be interested to hear your
> experience.
> cu
> Stephan
