[mapserver-users] Standalone Mapserver 6.4 as WFS server - issues with responses
Guillaume Sueur
no-reply at neogeo-online.net
Wed Nov 27 06:43:28 PST 2013
Did you properly set for each layer a "wfs_extent" ? Than can help.
Best regards
Guillaume
Le 26/11/13 12:26, Lars I. Nielsen a écrit :
> Hi,
> I'm still having problems with my setup of a WFS server using Mapserver 6.4.0 :-(
> My GetCapabilities requests take forever (or more precisely 5 minutes) to finish. Mapserver finishes in a split second, and returns a full document, but the connection - regardless of it being an url in a browser, or running ogrinfo.exe or some other program - stays open for circa 5 minutes before it finishes/times out.
> How can I get Mapserver/something-else to force closing the connection ?
> Mapserver runs as a standalone exe under IIS v6 on Windows 2003, but there's nothing in the IIS setup that I can find that prompts this behaviour.
> http://hvmgo01.hvenegaard.dk/mswfs/?map=BallerupGO_WFS.map&service=WFS&version=1.0.0&request=getcapabilities
> Any advise will be helpful :-)
> Kind regards / Med venlig hilsen
> Lars I. Nielsen
> Landinspektør, Senior GIS Programmør og Konsulent
> Hvenegaard og Jens Bo Landinspektører A/S
> Rugaardsvej 55, DK-5000 Odense C
> Denmark
> Tel. +45 6313 5050
> http://www.hvenegaard.dk
> -----Oprindelig meddelelse-----
> Fra: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] På vegne af Lars I. Nielsen
> Sendt: 26. november 2013 10:35
> Til: Rahkonen Jukka; mapserver-users at lists.osgeo.org
> Emne: Re: [mapserver-users] Standalone Mapserver 6.4 as WFS server - issues with responses
> Hi Jukka,
> It turns out that it was my adding - PROCESSING "CLOSE_CONNECTION=DEFER" - statements to my layer definitions that blocked fetching attributes from other layers than the first.
> Apparently the OGR VRT frameworks needs to open separate connections, and keeping the first connection open blocked subsequent connections.
> This part now works :-)
> Still working on other issues though ...
> Lars I. Nielsen
> Landinspektør, Senior GIS Programmør og Konsulent Hvenegaard og Jens Bo Landinspektører A/S Rugaardsvej 55, DK-5000 Odense C Denmark Tel. +45 6313 5050 http://www.hvenegaard.dk
> Fra: Rahkonen Jukka [mailto:jukka.rahkonen at mmmtike.fi]
> Sendt: 19. november 2013 15:59
> Til: Lars I. Nielsen; mapserver-users at lists.osgeo.org
> Hi,
> I can only show how my MS 6.2.1 server reacts
> http://hip.latuviitta.org/cgi-bin/mapserver_wfs?service=wfs&version=1.0.0&request=DescribeFeatureType<http://hip.latuviitta.org/cgi-bin/mapserver_wfs?service=wfs&version=1.1.0&request=DescribeFeatureType>
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Lars I. Nielsen [lin at hvenegaard.dk] puolesta
> Lähetetty: 19. marraskuuta 2013 16:16
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Standalone Mapserver 6.4 as WFS server - issues with responses
> Hi,
> I got the standalone Mapserver 6.4 x64 up and running, but there are still some issues:
> If I run "request=describefeaturetype" on any of the three typenames in my setup, it returns its list of attributes as it should.
> But if I omit the typename, wanting Mapserver to return a description of all three typenames (which is a valid request), it only returns the attributes for the first !??
> Is this WAD, or is Mapserver forgetting to return attributes for the latter two typenames (as I suspect) ?
> The server is online on this address if anyone wants to have a look:
> DescribeFeatureType that works: http://hvmgo01.hvenegaard.dk/mswfs/?map=BallerupGO_WFS.map&service=WFS&version=1.0.0&request=describefeaturetype&typename=GO_Flader
> DescribeFeatureType that doesn't work: http://hvmgo01.hvenegaard.dk/mswfs/?map=BallerupGO_WFS.map&service=WFS&version=1.0.0&request=describefeaturetype
> Lars I. Nielsen
> Landinspektør, Senior GIS Programmør og Konsulent Hvenegaard og Jens Bo Landinspektører A/S Rugaardsvej 55, DK-5000 Odense C Denmark Tel. +45 6313 5050 http://www.hvenegaard.dk<http://www.hvenegaard.dk/>
