[mapserver-users] Canot get around: WMS server error. Invalid layer(s) given in the LAYERS parameter.r
thomas bonfort
thomas.bonfort at gmail.com
Tue Oct 1 10:10:24 PDT 2013
Paul, please do not create new email threads for issues you have
already posted beforehand. If you had followed the instructions Jukka
took the time to write down for you in that previous thread, you would
have probably noticed that passing LAYER=TestMap is not valid for WMS,
you should be using LAYERS=TestMap
thomas
On 1 October 2013 18:57, <Paul.Sheedy at bentley.com> wrote:
> I installed MS4W a few days ago to put together a small proof-of-concept.
> I've been through the tutorial, which I got to work with a little tweaking.
> When I attempt to use an Oracle spatial table, I get a MS server error:
> Invalid layers(s)... error - which gives me no indication where I am going
> wrong.
> Can anyone spot a problem here? I am running out of hair to pull out.
> I have the Oracle client installed on my local machine and am attempting to
> draw a map from a spatial table on a local vm, on which I have Oracle
> Spatial running (10g).
> I tried OGRINFO using the Oracle login credentials and table name - with
> immediate success.
> mapserv -v shows that ORACLESPATIAL is a valid option
> GetCapabiltiies contains no warnings
> The map file is very simple - I have tried at least one hundred variations.
> The data table has a SRID (though I have other tables with SRIDs and tables
> without). I've included the SRID in wms_srs and I have excluded it. I am
> beginning to believe the problem lies elsewhere - but have no idea what
> approach to use to find it, other than stabbing in the dark.
> The map file contents are:
> MAP
> NAME "Map1"
> SIZE 600 400
> WEB
> IMAGEPATH "/tmp/ms_tmp/"
> TEMPLATE "..\Templates\TEMPLATE2.HTML"
> METADATA
> "wms_enable_request" "*"
> "wms_title" "TestMap"
> "wms_srs" "EPSG:2205"
> END
> END
> LAYER
> NAME TestMap
> TYPE LINE
> STATUS ON
> UNITS METERS
> CONNECTIONTYPE ORACLESPATIAL
> CONNECTION "test_user/test_user at LOCALVM1"
> DATA "SHAPE FROM (SELECT SHAPE FROM XNA_ROUTES)"
> METADATA
> "wms_name" "TestMap"
> "wms_title" "TestMapTitle"
> "wms_srs" "EPSG:4326"
> "wms_format" "image/gif"
> END
> END #LAYER
> END #MAP
> mapserver-users at lists.osgeo.org
