[mapserver-users] [EXTERNAL] Canot get around: WMS server error. Invalid layer(s) given in the LAYERS parameter.r
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Tue Oct 1 10:07:50 PDT 2013
Paul,
What is your WMS Request? And what does your GetCapabilities look like? MapServer might have renamed (added _1) to your TestMap layer name because your map is named TestMap. Layer names are also case sensitive.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
From: "Paul.Sheedy at bentley.com<mailto:Paul.Sheedy at bentley.com>" <Paul.Sheedy at bentley.com<mailto:Paul.Sheedy at bentley.com>>
Date: Tuesday, October 1, 2013 12:57 PM
To: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [EXTERNAL] [mapserver-users] Canot get around: WMS server error. Invalid layer(s) given in the LAYERS parameter.r
Resent-From: Michael Smith <michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>>
I installed MS4W a few days ago to put together a small proof-of-concept. I've been through the tutorial, which I got to work with a little tweaking. When I attempt to use an Oracle spatial table, I get a MS server error: Invalid layers(s)... error - which gives me no indication where I am going wrong.
Can anyone spot a problem here? I am running out of hair to pull out.
I have the Oracle client installed on my local machine and am attempting to draw a map from a spatial table on a local vm, on which I have Oracle Spatial running (10g).
I tried OGRINFO using the Oracle login credentials and table name - with immediate success.
mapserv -v shows that ORACLESPATIAL is a valid option
GetCapabiltiies contains no warnings
The map file is very simple - I have tried at least one hundred variations.
The data table has a SRID (though I have other tables with SRIDs and tables without). I've included the SRID in wms_srs and I have excluded it. I am beginning to believe the problem lies elsewhere - but have no idea what approach to use to find it, other than stabbing in the dark.
The map file contents are:
MAP
NAME "Map1"
SIZE 600 400
WEB
IMAGEPATH "/tmp/ms_tmp/"
TEMPLATE "..\Templates\TEMPLATE2.HTML"
METADATA
"wms_enable_request" "*"
"wms_title" "TestMap"
"wms_srs" "EPSG:2205"
END
END
LAYER
NAME TestMap
TYPE LINE
STATUS ON
UNITS METERS
CONNECTIONTYPE ORACLESPATIAL
CONNECTION "test_user/test_user at LOCALVM1"
DATA "SHAPE FROM (SELECT SHAPE FROM XNA_ROUTES)"
METADATA
"wms_name" "TestMap"
"wms_title" "TestMapTitle"
"wms_srs" "EPSG:4326"
"wms_format" "image/gif"
END
END #LAYER
END #MAP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131001/e38cf99c/attachment-0001.html>
