[mapserver-users] Compiling mapserver 6.4
thomas bonfort
thomas.bonfort at gmail.com
Thu Oct 3 06:13:47 PDT 2013
On 2 October 2013 01:45, Nahum Castro <pedro1_72 at yahoo.com> wrote:
> Hello all
> Says Fridibi is incompatible?
> Which version is compatible?
> I have 0.19.2
that should be fine. we use pkg-config to infer the location of libs
and headers, what does `pkg-config --libs fribidi` give ?
thomas
> Linking CXX shared library libmapserver.so
> /usr/bin/ld: skipping incompatible
> /usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../../libfribidi.so when searching
> for -lfribidi
> /usr/bin/ld: skipping incompatible /usr/lib/libfribidi.so when searching for
> -lfribidi
> /usr/bin/ld: cannot find -lfribidi
> collect2: ld devolvió el estado de salida 1
> make[2]: *** [libmapserver.so.6.4.0] Error 1
> make[1]: *** [CMakeFiles/mapserver.dir/all] Error 2
> make: *** [all] Error 2
> Thanks.
> Please add this lines to:
> FindPostgreSQL.cmake
> Not all of us use Ubuntu :)
> # - Find PostgreSQL
> # Find the PostgreSQL includes and client library
> # This module defines
> # POSTGRESQL_INCLUDE_DIR, where to find POSTGRESQL.h
> # POSTGRESQL_LIBRARY, the libraries needed to use POSTGRESQL.
> # POSTGRESQL_FOUND, If false, do not try to use PostgreSQL.
> # Copyright (c) 2013 Thomas Bonfort
> find_path(POSTGRESQL_INCLUDE_DIR libpq-fe.h
> /usr/include/server
> /usr/include/postgresql
> /usr/include/pgsql/server
> /usr/local/pgsql/include
> /usr/local/include/pgsql/server
> /usr/include/postgresql/server
> /usr/include/postgresql/*/server
> /usr/local/include/postgresql/server
> /usr/local/include/postgresql/*/server
> $ENV{ProgramFiles}/PostgreSQL/*/include/server
> $ENV{SystemDrive}/PostgreSQL/*/include/server
> find_library(POSTGRESQL_LIBRARY NAMES pq libpq
> PATHS
> /usr/lib
> /usr/local/pgsql/lib
> /usr/local/lib
> /usr/lib/postgresql
> /usr/lib64
> /usr/local/lib64
> /usr/lib64/postgresql
> $ENV{ProgramFiles}/PostgreSQL/*/lib/ms
> $ENV{SystemDrive}/PostgreSQL/*/lib/ms
> set(POSTGRESQL_INCLUDE_DIRS ${POSTGRESQL_INCLUDE_DIR})
> set(POSTGRESQL_LIBRARIES ${POSTGRESQL_LIBRARY})
> include(FindPackageHandleStandardArgs)
> find_package_handle_standard_args(POSTGRESQL DEFAULT_MSG POSTGRESQL_LIBRARY
> POSTGRESQL_INCLUDE_DIR)
> mark_as_advanced(POSTGRESQL_LIBRARY POSTGRESQL_INCLUDE_DIR)
> Thanks.
> Nahum Castro
> Leon, Guanajuato, Mexico
> http://www.leon-linux.com
> e-mail: pedro1_72 [en] yahoo [punto] com
> mapserver-users at lists.osgeo.org
