[mapserver-users] WFS Output formats - dxf/dgn problems
TOGA - Torben Gade
toga at orbicon.dk
Fri Oct 4 00:06:40 PDT 2013
I'm trying to generate 4 specific output formats from mapserver.
Shape- and tab files are working great - no problems.
Dgn (microstation) and dxf (aotocad) attempts, however, generate an error I have not been able to convert into corrective actions.
I believe to have followed the guidance on http://www.gdal.org/ogr/ for the specific drivers.
I am hoping someone out there has a working configuration for these formats or is able to shed some light on the matter?
The error I get is:
System.ApplicationException was unhandled by user code
HResult=-2146232832
Message=msOGRWriteFromQuery(): General error message. OGR CreateDataSource failed for 'C:/Temp/524e6523_1218_4/result.dat' with driver 'DXF'.
Source=mapscript_csharp
StackTrace:
at OSGeo.MapServer.mapObj.OWSDispatch(OWSRequest req)
at Orbicon.WxS.WxS.ProcessRequest(HttpContext context) in c:\Udv\csharp\Orbicon WxS\Kildekode\WxS.ashx.cs:line 75
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Looking into mapogroutput.c(win32 6.2) did not enlighten me any further - I can see there are 2 possible origins for the message..
My mapfile configuration (working for shp and tab, have tried simple/muiltipart, and memory, same result) is:
OUTPUTFORMAT
NAME "SHP"
DRIVER "OGR/ESRI Shapefile"
FORMATOPTION "STORAGE=filesystem"
FORMATOPTION "FORM=zip"
END
OUTPUTFORMAT
NAME "TAB"
DRIVER "OGR/MapInfo File"
END
OUTPUTFORMAT
NAME "DGN"
DRIVER "OGR/DGN"
FORMATOPTION "Seed=c:\temp\seed_2d.dgn"
END
OUTPUTFORMAT
NAME "DXF"
DRIVER "OGR/DXF"
END
Best regards,
Torben Gade
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131004/ae4fe656/attachment.html>
