[mapserver-users] MapCache 1.2.0 and NGNIX 1.5 problem
Pascual Ayats, Victor
victor.pascual at icc.cat
Wed Oct 9 01:31:40 PDT 2013
Thanks for the point,
Indeed, using strace command, I created a debug LOG to spawn-FGC and saw this:
22419 rt_sigaction(SIGPIPE, {SIG_DFL, [PIPE], SA_RESTORER|SA_RESTART, 0x3259032920}, {0x35d0006290, [], SA_RESTORER, 0x3259032920}, 8) = 0
22419 fstat(1, {st_dev=makedev(0, 8), st_ino=160933, st_mode=S_IFIFO|0600, st_nlink=1, st_uid=502, st_gid=502, st_blksize=4096, st_blocks=0, st_size=0, st_atime=2013/10/09-07:51:04, st_mtime=2013/10/09-07:51:04, st_ctime=2013/10/09-07:51:04}) = 0
22419 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fb6d96f6000
22419 write(1, "Status: 403 Forbidden\r\nContent-Type: text/plain\r\n\r\n403 Forbidden\r\n", 66 <unfinished ...>
22415 <... select resumed> ) = 1 (in [6])
22415 read(6, "Status: 403 Forbidden\r\nContent-Type: text/plain\r\n\r\n403 Forbidden\r\n", 4096) = 66
22415 select(9, [6 8], NULL, NULL, NULL <unfinished ...>
22419 <... write resumed> ) = 66
22419 write(2, "Cannot get script name, are DOCUMENT_ROOT and SCRIPT_NAME (or SCRIPT_FILENAME) set and is the script executable?", 112 <unfinished ...>
22415 <... select resumed> ) = 1 (in [8])
22415 read(8, "Cannot get script name, are DOCUMENT_ROOT and SCRIPT_NAME (or SCRIPT_FILENAME) set and is the script executable?", 4096) = 112
22415 write(2, "Cannot get script name, are DOCUMENT_ROOT and SCRIPT_NAME (or SCRIPT_FILENAME) set and is the script executable?", 112) = 112
22419 <... write resumed> ) = 112
22419 write(2, "\n", 1 <unfinished ...>
22415 read(8, "\n", 4096) = 1
22415 write(2, "\n", 1) = 1
22419 exit_group(99) = ?
22415 read(6, "", 4096) = 0
22415 close(6) = 0
22415 select(9, [8], NULL, NULL, NULL) = 1 (in [8])
22415 read(8, "", 4096) = 0
22415 close(8) = 0
22415 write(3, "\1\6\0\1\0B\6\0Status: 403 Forbidden\r\nContent-Type: text/plain\r\n\r\n403 Forbidden\r\n\0\0\0\0\0\0\1\6\0\1\0\0\0\0\1\3\0\1\0\10\0\0\0\0\0\0\0\0\0\0", 104) = 104
22415 shutdown(3, 1 /* send */) = 0
22415 select(4, [3], NULL, NULL, {2, 0}) = 1 (in [3], left {1, 999997})
22415 read(3, "", 1024) = 0
22415 close(3) = 0
22415 accept(0,
I Google the error "Cannot get script name, are DOCUMENT_ROOT and SCRIPT_NAME (or SCRIPT_FILENAME) set and is the script executable?" and there's not a clean response or solution.
So if you have any clue or idea to continue move forward I'll be very grateful.
Thanks in advance
Victor
________________________________________
De: thomas bonfort [thomas.bonfort at gmail.com]
Enviat el: divendres, 4 / octubre / 2013 10:00
Per a: Pascual Ayats, Victor
A/c: mapserver-users at lists.osgeo.org
Tema: Re: [mapserver-users] MapCache 1.2.0 and NGNIX 1.5 problem
You might want to check the spawn-fcgi logs. Note that there is no
place in the mapcache code that emits a 403 error, i.e. that 403 is
coming from something else than mapcache.
thomas
On 4 October 2013 09:38, Pascual Ayats, Victor <victor.pascual at icc.cat> wrote:
> Hi users,
> I compiled and installed MapServer 6.4 and MapCache 1.2 as fastcgi in a
> Linux Red Hat 6 (64 bits)
> I compiled NGNIX 1.5 (adding MapCache as a module) and installed fcgiwarp
> and spanw-fcgi in order to run fastcgi in NGNIX.
> MapServer works very well and fast but I have a problem dealing with
> MapCache. MapCahce works well in GetCapbilities requests or when already
> existing tiles in the file system pre generated by mapcacahe_seed , but when
> I send a request and the tile not exist then I received a “403 Forbbiden”
> error.
> So MapCache “fails” when try to generate a tile on the fly.
> The 403 Forbbiden error not comes from NGINX (not appear in error log), so
> it seems that the error comesfrom the spanw-cgi process or Mapcahe .fcgi??
> I have no idea what might happen and who to solve it
> Here’s the spanw-fcgi config
> FCGI_SOCKET=/var/run/fcgiwrap.socket
> FCGI_PROGRAM=/usr/local/sbin/fcgiwrap
> FCGI_USER=nginx
> FCGI_GROUP=nginx
> FCGI_EXTRA_OPTIONS="-M 0777"
> OPTIONS="-u $FCGI_USER -g $FCGI_GROUP -s $FCGI_SOCKET -S $FCGI_EXTRA_OPTIONS
> -F 1 -P /var/run/spawn-fcgi.pid -- $FCGI_PROGRAM"
> Here’s the nginx .conf
> #Mapserver
> location /maps/ {
> fastcgi_pass unix:/var/run/fcgiwrap.socket;
> include fastcgi_params;
> fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
> #Mapcache
> location ~ ^/mapcache(?<path_info>/.*|$) {
> set $url_prefix "/mapcache";
> mapcache /opt/geo/data/mapcache/mapcache.xml;
> error_page 404 = @fcgi_mapcache;
> #MapCache 404
> location @fcgi_mapcache {
> Any help will be greatly appreciated
> Best regards
> Victor Pascual Ayats
