[mapserver-users] allowing MapServer access to data on another windows machine?
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Tue Oct 8 14:10:27 PDT 2013
If I remember right, there are no problems if you can run Apache as a program by starting it from the command window (\ms4w\apache\bin\httpd). Then you will run Apache under the login account and drives which are mapped to a drive letter can be accessed. But it means that you must keep the console open. However, if you can tolerate it during the down time of your main server then it should be a fast and easy solution.
-Jukka-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Richard Greenwood [richard.greenwood at gmail.com] puolesta
Lähetetty: 8. lokakuuta 2013 23:58
Cc: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] allowing MapServer access to data on another windows machine?
Jukka is correct, it is an Apache problem. IIS is the same. The web server is not allowed to access resources on the network. If your network is on a domain then you can give the apache 'user' a domain account. It's a little flaky but it does work. I haven't tried in a workgroup but it might be possible to give the apache user account permissions on the other machine. Alternatively, how about an external USB drive? Since it would be plugged into your server it would be treated as a local resource.
Good luck,
Rich
On Tue, Oct 8, 2013 at 1:29 PM, Rahkonen Jukka <jukka.rahkonen at mmmtike.fi<mailto:jukka.rahkonen at mmmtike.fi>> wrote:
I never managed to make it to work before we acquired more disks but it is about Apache and this is the reason
" By default, all Apache services are registered to run as the system user (the LocalSystem account). The LocalSystem account has no privileges to your network via any Windows-secured mechanism, including the file system, named pipes, DCOM, or secure RPC. It has, however, wide privileges locally. "
Some advice to start with is at http://httpd.apache.org/docs/2.2/platform/windows.html
-Jukka Rahkonen-
________________________________________
Mark Volz
> Hello
> I am planning to reinstall windows on our main web server. While it is down I am going to use an old machine. It does not have enough hard disk space for all of our data. I mapped the Z drive to a second old machine which will temporary hold the excess mapserver gis data. I received an error " Unable to access file. (Z:/ms4wCache/source/Picto2011Lyon/Picto2011.shp)\nmsShapefileOpen(): Unable to access file."
> Question: what do I need to do to allow mapserver to access data that is stored on another machine?
thanks
Mark Volz, GISP
GIS Specialist
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard Greenwood
richard.greenwood at gmail.com<mailto:richard.greenwood at gmail.com>
www.greenwoodmap.com<http://www.greenwoodmap.com>
