[mapserver-users] Create a Run-time WMS Server
Daniel Morissette dmorissette at mapgears.com
Fri Oct 25 06:24:23 PDT 2013
The URL parameter "map.layer[test]=DATA+012.tif" should work as well
with WMS as with the traditional mode=map. If it doesn't then there may
be a bug.
P.S. Your request to render arbitrary data files through a URL (without
creating a mapfile) reminded me of http://mapfart.com/ which was
presented at FOSS4G-NA earlier this year and uses mapserver under the
hood. It may not be useful for those who need a compliant WMS, but for
simpler uses just to render a data file there is real potential there.
Daniel
On 13-10-25 8:45 AM, aborruso wrote:
> Dear all,
> I have a WMS server with only one layer.
> I have SET a DATAPATTERN  rule and I would like it to show only the datafile
> I call with a specific URL.
> In mode map I can use this kind of URL:
> http://myserver/cgi-bin/mapserv?map=/temp/test.map&mode=map&map.layer[test]=DATA+012.tif
> It works and I have only 012.tif rendered.
> Is it possible to change WMS Server ar run-time? If it's yes what kind of
> SERVER URL I must set in a WMS client?
> I think it's wrong to use something like
> http://myserver/cgi-bin/mapserv?map=/temp/test.map&map.layer[test]=DATA+012.tif&&SERVICE=WMS&VERSION=1.0.0&REQUEST=GetCapabilities
> Thank you
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Create-a-Run-time-WMS-Server-tp5085768.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
More information about the MapServer-users mailing list
