[mapserver-users] Perpendicular offset different in Mapfile and SLD
thomas bonfort
thomas.bonfort at gmail.com
Mon Oct 28 07:14:40 PDT 2013
Gertjan,
I've opened a pull-request for this issue at
https://github.com/mapserver/mapserver/pull/4801 . Could you please
comment in that issue if the fix is correct?
thomas
On 28 October 2013 13:43, Gertjan van Oosten <gertjan at west.nl> wrote:
> Hi all,
> I've noticed that there's an implementation difference between
> specifying a perpendicular offset in the STYLE section of the Mapfile:
> STYLE
> OFFSET 3 -99
> END
> and specifying it via an SLD:
> <sld:LineSymbolizer>
> <sld:PerpendicularOffset>3</sld:PerpendicularOffset>
> The first one, via the Mapfile, does a complex offset calculation
> (function msOffsetPolyline() in maputil.c; calls msOffsetCurve() for
> perpendicular offset).
> The second one, via the SLD, simply does a displacement by the given
> value in both the X and Y directions (function msSLDParseLineSymbolizer()
> in mapogcsld.c).
> These two produce quite different results.
> [Note that the SLD one would be the same as specifying "OFFSET 3 3" in
> the Mapfile.]
> My questions:
> Is there a reason the two methods are different?
> If not, would it be possible to change the SLD one to use the same
> calculations as done for the Mapfile?
> Kind regards,
> -- Gertjan van Oosten, Principal Consultant, West Consulting B.V.
> -- gertjan at West.NL +31 15 2191 600 www.west.nl
> mapserver-users at lists.osgeo.org
