[mapserver-users] mapcache kml--how to use?
thomas bonfort
thomas.bonfort at gmail.com
Wed Sep 11 09:03:01 PDT 2013
Peter,
The KML address to use would be
http://mrdata.usgs.gov/mapcache/kml/sgmc@WGS84.kml
However there seems to be something very wrong with your setup... Are
you piggybacking mapcache onto itself, i.e. does your mapcache.xml
point to wms sources who's url also starts with http://mrdata.usgs.gov
(or even very worse, http://mrdata.usgs.gov/mapcache) ? In that case
you have a risk of deadlock, the probability and/or frequency of which
are dependant on the webserver configuration, and that can be very
high if you're using mapcache as a source for itself. You can send me
your mapcache.xml file offlist if you want me to have a look.
regards,
thomas
On Tue, Sep 10, 2013 at 10:18 PM, Schweitzer, Peter
<pschweitzer at usgs.gov> wrote:
> I have a mapcache that is doing a fine job (I think) serving tiles to
> OpenLayers. Now I wonder if it is possible to use these tiles in
> Google Earth. Can someone advise me how to do this?
> Here's what I tried: Opening Google Earth, I chose "Network Link"
> from the "Add" menu, entered a simple title ("SGMC") and guessed at
> the URL to put into the Link field. I tried
> http://mrdata.usgs.gov/mapcache/kml/sgmc@WGS84 as well as
> http://mrdata.usgs.gov/mapcache/kml/sgmc@g and
> http://mrdata.usgs.gov/mapcache/kml/sgmc@GoogleMapsCompatible
> In each case Google Earth seemed to "freeze" but it also seemed to
> generate many requests for tiles from the server (I see the requests
> in the web server log file). No image data appeared in Google Earth,
> though. So I'm guessing that I may be somewhat close but I'm doing
> something wrong or perhaps I'm trying the wrong thing altogether.
> I am grateful for any advice!
> Peter
> Peter N. Schweitzer (U.S. Geological Survey, Reston, VA 20192)
> (703) 648-6533 email: pschweitzer at usgs.gov
> http://geology.usgs.gov/peter/
> mapserver-users at lists.osgeo.org
