[mapserver-users] TYPE/FONT/SIZE breaks labels
Michael McInnis
mmcinnis59 at msn.com
Mon Sep 16 10:51:59 PDT 2013
Thanks, that seems to have fixed things. It only seems to work with arial but the sizes work now.
I'll look into how to get full control of installed fonts I guess.
Michael McInnis
6033 44th Ave. N.E.
Seattle, WA 98115
206 517-4701
> From: jukka.rahkonen at mmmtike.fi
> To: mmcinnis59 at msn.com; mapserver-users at lists.osgeo.org
> Subject: VS: [mapserver-users] TYPE/FONT/SIZE breaks labels
> Date: Mon, 16 Sep 2013 17:09:04 +0000
> Hi,
> Add DEBUG 5 into your LAYER and you may see from the MS_ERRORFILE what is the problem. My bet is that you are missing the FONTSET http://www.mapserver.org/mapfile/fontset.html
> -Jukka Rahkonen-
> ________________________________
> Michael McInnis wrote:
> > Mapservers!
> > I have bailed on dynamically generating labels and fell back to a .map based solution and may have found the primary problem. If I enable TYPE or FONT or SIZE in the LABEL section my map fails to display. I installed Truetype fonts on my Ubuntu system on Friday.
> > Does anyone know why the fonts will not function?
> LAYER
> CONNECTIONTYPE POSTGIS
> NAME airports
> CONNECTION "host=xxxx dbname=xxxx user=xxxx password=xxxx port=xxxx"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> #DATA "geom From airports"
> DATA "geom From (select a.icao, geom From airports a left join airportdata e on a.icao = e.icao where e.icao Is Not Null) as subquery using unique icao using srid=4326"
> STATUS ON
> TYPE POINT
> LABELITEM "icao"
> CLASS
> LABEL
> #TYPE truetype
> #FONT "sans"
> #SIZE 8
> ANTIALIAS TRUE
> POSITION AUTO
> PARTIALS TRUE
> MINDISTANCE 100
> BUFFER 4
> COLOR 0 0 0
> END
> NAME "airportsClass"
> STYLE
> SYMBOL 'circle-filled'
> SIZE 3
> COLOR 255 22 22
> END
> END # Class
> END # Layer
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130916/604a5922/attachment.html>
