[mapserver-users] Bad BBOX passed to db query
Jack Walters
jack.walters at zonarsystems.com
Mon Sep 23 16:13:20 PDT 2013
UPDATE - Possible fix
- Removed PROJECTION items from all layers
- Set main PROJECTION to AUTO
- Only reference to epsg 4326 is in MAP->METADATA wms_srs and postgresql
db calls
All items are now returning as expected. BBOX now:
GeomFromText('POLYGON((-179.52099606876
-21.9022779637684,-179.52099606876 74.0074402855723,179.129882837677
74.0074402855723,179.129882837677 -21.9022779637684,-179.52099606876
-21.9022779637684))',4326)
Any issues using it this way? Could the extra PROJECTION statments cause
mapserver to calculate the longitude differently?
Thanks,
Jack Walters
Web Development Engineer III
Zonar Systems
Confidentiality Notice: This e-mail may contain proprietary information some of which may be legally privileged. It is for the intended recipient(s) only. If you believe that it has been sent to you in error, please notify the sender by reply e-mail and delete the message. Any disclosure, copying, distribution or use of this information by someone other than the intended recipient(s) is prohibited and may be unlawful.
