[mapserver-users] MapServer 6.4 Released
andy
andy at squeakycode.net
Tue Sep 17 12:52:58 PDT 2013
On 9/17/2013 2:28 PM, thomas bonfort wrote:
> patches/pull-requests welcome ;)
Ok, this seems to work for me.
-Andy
# - Find PostgreSQL
# Find the PostgreSQL includes and client library
# This module defines
# POSTGRESQL_INCLUDE_DIR, where to find POSTGRESQL.h
# POSTGRESQL_LIBRARY, the libraries needed to use POSTGRESQL.
# POSTGRESQL_FOUND, If false, do not try to use PostgreSQL.
# Copyright (c) 2013 Thomas Bonfort
find_program(PG_CONFIG NAMES pg_config
PATHS
$ENV{ProgramFiles}/PostgreSQL/*/bin
$ENV{SystemDrive}/PostgreSQL/*/bin
if (PG_CONFIG)
exec_program( ${PG_CONFIG} ARGS "--includedir" OUTPUT_VARIABLE PG_INC_PATH )
exec_program( ${PG_CONFIG} ARGS "--libdir" OUTPUT_VARIABLE PG_LIB_PATH )
else()
message(WARNING "pg_config not found, will try some defaults")
endif()
find_path(POSTGRESQL_INCLUDE_DIR libpq-fe.h
${PG_INC_PATH}
/usr/include/server
/usr/include/postgresql
/usr/include/pgsql/server
/usr/local/include/pgsql/server
/usr/include/postgresql/server
/usr/include/postgresql/*/server
/usr/local/include/postgresql/server
/usr/local/include/postgresql/*/server
$ENV{ProgramFiles}/PostgreSQL/*/include/server
$ENV{SystemDrive}/PostgreSQL/*/include/server
find_library(POSTGRESQL_LIBRARY NAMES pq libpq
PATHS
${PG_LIB_PATH}
/usr/lib
/usr/local/lib
/usr/lib/postgresql
/usr/lib64
/usr/local/lib64
/usr/lib64/postgresql
$ENV{ProgramFiles}/PostgreSQL/*/lib/ms
$ENV{SystemDrive}/PostgreSQL/*/lib/ms
set(POSTGRESQL_INCLUDE_DIRS ${POSTGRESQL_INCLUDE_DIR})
set(POSTGRESQL_LIBRARIES ${POSTGRESQL_LIBRARY})
include(FindPackageHandleStandardArgs)
find_package_handle_standard_args(POSTGRESQL DEFAULT_MSG POSTGRESQL_LIBRARY POSTGRESQL_INCLUDE_DIR)
mark_as_advanced(POSTGRESQL_LIBRARY POSTGRESQL_INCLUDE_DIR)
