[mapserver-users] MapServer 6.4 Released
andy
andy at squeakycode.net
Tue Sep 17 13:15:56 PDT 2013
On 9/17/2013 9:09 AM, thomas bonfort wrote:
> The MapServer team is pleased to announce the release of MapServer
> 6.4, along with the joint release of MapCache 1.2.
> Details of the new features, migration instructions, and download
> links can be found on the dedicated announcement page at
> http://www.mapserver.org/development/announce/6-4.html .
> cheers,
> The MapServer PSC
I start with:
cmake -DCMAKE_INSTALL_PREFIX=/tmp/map -DWITH_PERL=1 ..
it runs ok, and displays:
-- Will install files to /tmp/map
-- Configuring done
-- Generating done
then I run make, which compiles fine. But "make install" has a problem
with mapscript and tries to copy it to /usr/local/lib64, not /tmp/map.
[ 90%] Built target mapserver
[ 90%] Built target legend
[ 91%] Built target mapserv
[ 92%] Built target msencrypt
[ 92%] Built target scalebar
[ 93%] Built target shp2img
[ 94%] Built target shptree
[ 95%] Built target shptreetst
[ 96%] Built target shptreevis
[ 97%] Built target sortshp
[ 98%] Built target tile4ms
[100%] Built target perlmapscript
Install the project...
-- Install configuration: ""
-- Installing: /tmp/map/bin/sortshp
-- Set runtime path of "/tmp/map/bin/sortshp" to
"/tmp/map/lib:/usr/local/pg93/lib:/usr/local/lib"
-- Installing: /tmp/map/bin/shptree
-- Set runtime path of "/tmp/map/bin/shptree" to
-- Installing: /tmp/map/bin/shptreevis
-- Set runtime path of "/tmp/map/bin/shptreevis" to
-- Installing: /tmp/map/bin/msencrypt
-- Set runtime path of "/tmp/map/bin/msencrypt" to
-- Installing: /tmp/map/bin/legend
-- Set runtime path of "/tmp/map/bin/legend" to
-- Installing: /tmp/map/bin/scalebar
-- Set runtime path of "/tmp/map/bin/scalebar" to
-- Installing: /tmp/map/bin/tile4ms
-- Set runtime path of "/tmp/map/bin/tile4ms" to
-- Installing: /tmp/map/bin/shptreetst
-- Set runtime path of "/tmp/map/bin/shptreetst" to
-- Installing: /tmp/map/bin/shp2img
-- Set runtime path of "/tmp/map/bin/shp2img" to
-- Installing: /tmp/map/bin/mapserv
-- Set runtime path of "/tmp/map/bin/mapserv" to
-- Installing: /tmp/map/lib/libmapserver.so.6.4.0
-- Installing: /tmp/map/lib/libmapserver.so.1
-- Set runtime path of "/tmp/map/lib/libmapserver.so.6.4.0" to
-- Installing: /usr/local/lib64/perl5/auto/mapscript/mapscript.so
CMake Error at mapscript/perl/cmake_install.cmake:38 (FILE):
file INSTALL cannot copy file
"/home/andy/gis/mapserver/mapserver-6.4.0/buid/mapscript/perl/mapscript.so"
to "/usr/local/lib64/perl5/auto/mapscript/mapscript.so".
Call Stack (most recent call first):
cmake_install.cmake:273 (INCLUDE)
make: *** [install] Error 1
Any hints how I might fix this?
-Andy
