[mapserver-users] MapServer 6.4 Released
andy
andy at squeakycode.net
Tue Sep 17 13:55:46 PDT 2013
On 9/17/2013 3:15 PM, andy wrote:
> On 9/17/2013 9:09 AM, thomas bonfort wrote:
>> The MapServer team is pleased to announce the release of MapServer
>> 6.4, along with the joint release of MapCache 1.2.
>> Details of the new features, migration instructions, and download
>> links can be found on the dedicated announcement page at
>> http://www.mapserver.org/development/announce/6-4.html .
>> cheers,
>> The MapServer PSC
> I start with:
> cmake -DCMAKE_INSTALL_PREFIX=/tmp/map -DWITH_PERL=1 ..
> it runs ok, and displays:
> -- Will install files to /tmp/map
> -- Configuring done
> -- Generating done
> then I run make, which compiles fine. But "make install" has a problem
> with mapscript and tries to copy it to /usr/local/lib64, not /tmp/map.
> [ 90%] Built target mapserver
> [ 90%] Built target legend
> [ 91%] Built target mapserv
> [ 92%] Built target msencrypt
> [ 92%] Built target scalebar
> [ 93%] Built target shp2img
> [ 94%] Built target shptree
> [ 95%] Built target shptreetst
> [ 96%] Built target shptreevis
> [ 97%] Built target sortshp
> [ 98%] Built target tile4ms
> [100%] Built target perlmapscript
> Install the project...
> -- Install configuration: ""
> -- Installing: /tmp/map/bin/sortshp
> -- Set runtime path of "/tmp/map/bin/sortshp" to
> "/tmp/map/lib:/usr/local/pg93/lib:/usr/local/lib"
> -- Installing: /tmp/map/bin/shptree
> -- Set runtime path of "/tmp/map/bin/shptree" to
> -- Installing: /tmp/map/bin/shptreevis
> -- Set runtime path of "/tmp/map/bin/shptreevis" to
> -- Installing: /tmp/map/bin/msencrypt
> -- Set runtime path of "/tmp/map/bin/msencrypt" to
> -- Installing: /tmp/map/bin/legend
> -- Set runtime path of "/tmp/map/bin/legend" to
> -- Installing: /tmp/map/bin/scalebar
> -- Set runtime path of "/tmp/map/bin/scalebar" to
> -- Installing: /tmp/map/bin/tile4ms
> -- Set runtime path of "/tmp/map/bin/tile4ms" to
> -- Installing: /tmp/map/bin/shptreetst
> -- Set runtime path of "/tmp/map/bin/shptreetst" to
> -- Installing: /tmp/map/bin/shp2img
> -- Set runtime path of "/tmp/map/bin/shp2img" to
> -- Installing: /tmp/map/bin/mapserv
> -- Set runtime path of "/tmp/map/bin/mapserv" to
> -- Installing: /tmp/map/lib/libmapserver.so.6.4.0
> -- Installing: /tmp/map/lib/libmapserver.so.1
> -- Set runtime path of "/tmp/map/lib/libmapserver.so.6.4.0" to
> -- Installing: /usr/local/lib64/perl5/auto/mapscript/mapscript.so
> CMake Error at mapscript/perl/cmake_install.cmake:38 (FILE):
> file INSTALL cannot copy file
> "/home/andy/gis/mapserver/mapserver-6.4.0/buid/mapscript/perl/mapscript.so"
> to "/usr/local/lib64/perl5/auto/mapscript/mapscript.so".
> Call Stack (most recent call first):
> cmake_install.cmake:273 (INCLUDE)
> make: *** [install] Error 1
> Any hints how I might fix this?
> -Andy
In mapscript/perl/CMakeLists.txt, how about stripping the leading '/' so
that INSTALL() has a relative path instead of absolute:
set(CUSTOM_PERL_SITE_ARCH_DIR ${PERL_SITEARCH} CACHE DIR "Custom
installation directory for perl binary extension
# strip leading slash so INSTALL() uses CMAKE_INSTALL_PREFIX
string(SUBSTRING ${CUSTOM_PERL_SITE_ARCH_DIR} 1 -1
CUSTOM_PERL_SITE_ARCH_DIR)
Maybe?
-Andy
