[mapserver-users] WMS Server Optimization?
Andrea Peri
aperi2007 at gmail.com
Wed Apr 2 13:32:55 PDT 2014
I set always the EXTEND information at the layer level.
This speed really the startup of mapserver.
Without the EXTENT al layer level the WMS try to calculate it to respond at
a
GetCapability request.
I guess the wms_extents is not sufficient to speed up mapserver.
hope to help.
Andrea.
2014-04-02 21:55 GMT+02:00 gom <gord.mckenzie at canam.com>:
> I have created a Mapserver site and published a couple of large raster
> layers
> through WMS. They work as expected and perform quiite well.
> When i add the wms layers to Gaia or to Global Mapper they add and display
> great. I want to display the layers in AutoCAD Map. When I add the WMS
> layer there it takes 1.5 to 3 minutes to add the layer. After that it
> works
> fine. No other WMS layers behave like that in AutoCAD Map and as I
> mentioned previously, the layers don't work like that in any other program.
> The layers are made up of about 1600 PNG images that are referenced in the
> .map file by tileindexes. One layer is at 2 metre pixels and the other at
> 5
> metre pixels. If I remove the layer that references the 2 metre images and
> only use the 5 metre images, the layer is attached quite quickly. If I
> switch and use only the 2 metre image layer the speed is slow again.
> My output format is PNG8.
> The images are stored in the same projection as they are being queried.
> I have added the wms_extents metadata to each layer.
> The MAXGEOWIDTH is such that no data is queried on inital loading of the
> layer.
> I have asked the question in the AutoCAD support forums, from the AutoCAD
> MAp perspective, but was hoping there might be some suggestions as to
> configuration/map options, in Mapserver, that might help speed up this
> operation.
> Thanks
> http://osgeo-org.1560.x6.nabble.com/WMS-Server-Optimization-tp5132723.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140402/99554abb/attachment.html>
