[mapserver-users] Can't see any SVG Symbol with SVGCAIRO support
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Apr 7 10:08:03 PDT 2014
On 4/7/2014 12:02 PM, Ludovic Gnemmi wrote:
> i finally found that this problem was depending on svg file type.
> Some SVG files doesn't work with mapserver built with libsvg/libsvg-cairo.
> IE svg files provided with Qgis.
> These files cause assert (segmentation fault) => (freeSVGCache). The
> renderer_cache come with a NULL svg handle.
> I had to change all my SVG files. (With Inkscape : Save As PLAIN SVG file)
> This problem doesn't occur with librsvg but only with libsvg/libsvg-cairo.
Yes, this was a common problem when I original did a bunch of test with
Thomas. I was using a version of mapserv-6.1-dev in the original tests
and put together this test suite:
http://imaptools.com:8080/svg-test/
Most all of these SVG files would display correctly in mapserver.
I just put the test suite back up and based on:
MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
I looks like I'm seeing a lot more failures.
The trick was to flatten the SVG and save them a plain. Basically some
complex and nested symbols did not work and text objects needed to be
exploded to vectors.
I remember that there was some discussion about svg libraries and
licensing issues the impacted this but I forget the details.
Thomas - can you summarize the issues again?
Thanks,
-Steve W
