[mapserver-users] Upgrading Apache and PHP that came with MS4W
Thomas Raffin
traffin at sirap.fr
Mon Apr 14 10:03:00 PDT 2014
Hi James,
Thanks for your reply. Why did you choose to migrate from MS4W to IIS +
GisInternals build, and not to Apache + GisInternals builds?
Are you using PHP/MapScript?
Thomas
-----Original Message-----
From: "EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE" <james.evans.4 at us.af.mil>
To: tr <traffin at sirap.fr>, "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Date: Sun, 13 Apr 2014 15:07:33 +0000
Subject: RE: [mapserver-users] Upgrading Apache and PHP that came with MS4W
> Hi Thomas,
> I was forced to remove MS4W from our servers due to security
> vulnerabilities in Apache and PHP. I was able to get the GISInternals
> build working under IIS 7. It required a little more effort to get
> going, but so far it seems to be working. Here are the steps I had to
> follow to get it going:
> Turn on IIS6 Compatibility Mode
> Turn on CGI and ASP.Net in IIS
> Edit ISAPI and CGI Restrictions
> Check the box to allow Unspecified CGI Modules and to allow
> Unspecified ISAPI modules
> Look in the binary zip file and copy the following dlls to the
> Mapserver directory
> Hdf5.dll
> Hdf5_hl.dll
> Hdfdll.dll
> Geos.dll
> Szip.dll
> Openjp2.dll
> Then, I had to add this to my map file:
> CONFIG PROJ_LIB "C:\Program Files\MapServer\projlib"
> CONFIG GDAL_DATA "C:\Program Files\MapServer\gdal-data"
> Or you could just set environment variables for each.
> I also had to download and install PHP, and the Microsoft URL Rewrite
> module for IIS7. After that, I seem to be back to the same capability
> I had previously.
> James
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org
> [mapserver-users-bounces at lists.osgeo.org] on behalf of tr
> [traffin at sirap.fr]
> Sent: Friday, April 11, 2014 4:53 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Upgrading Apache and PHP that came with
> MS4W
> Hi Jeff,
> As each MS4W user I'm very interested by upgrading my install.
> Have you got any news, please? (Maybe an ETA?)
> Does the community edition will contain PHP Mapscript?
> Are there official or public informations about custom builds
> conditions
> please (I don't have response by contacting you or your organization
> directly)?
> Thanks for your work and the informations to come.
> Thomas
