[mapserver-users] mapcache check cache before testing source data?
jrumbolt
cankorusa at gmail.com
Thu Apr 24 21:48:37 PDT 2014
Thomas,
If my mapcache.xml file is as below... then it does contain a reference to
the data. I'd like that if a tile is in the cache then use it otherwise
generate from the source. Is there something that I should be doing
differently?
Cheers,
Jerry
<source name="dataset_356a6e96-cbd2-11e3-8549-06cb762f3bdb" type="wms">
<getmap>
<params>
<format>image/jpeg</format>
<layers>dataset</layers>
<map>/mnt/data/ogcservices/356a6e96-cbd2-11e3-8549-06cb762f3bdb.map</map>
<transparent>TRUE</transparent>
</params>
</getmap>
<http>
<url>http://127.0.0.1/cgi-bin/mapserv?map=/mnt/data/ogcservices/356a6e96-cbd2-11e3-8549-06cb762f3bdb.map</url>
</http>
</source>
<tileset name="dataset_356a6e96-cbd2-11e3-8549-06cb762f3bdb">
<cache>local-disk-cache</cache>
<source>dataset_356a6e96-cbd2-11e3-8549-06cb762f3bdb</source>
<grid max-cached-zoom="19" out-of-zoom-strategy="reassemble"
restricted_extent="8072159.16799 2628826.6365 8089036.32818
2645666.47154">GoogleMapsCompatible</grid>
<format>80jpeg</format>
<metadata>
<title>dataset</title>
</metadata>
</tileset>
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapcache-check-cache-before-testing-source-data-tp5136792p5137048.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
