[mapserver-users] An interesting SQL linestring building problem from postgres.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Dec 2 11:56:44 PST 2014
All,
I have a bunch of individual LINE segments in Postgres and want to display them via MapServer like so:
First:
* Get a chunk of them based on a set of IDs (a set of three for example) and a begin/end timestamp (got this figured out already)
* Take the result and combine up the separate line strings into multi-segment (grouped) lines ordered by ID, timestamp (got this figured out for individual IDs)
* Add a random number to each grouping of multi-line string rows for dynamic color-coding of each group. (got this figured out for individual IDs)
* Have results output as three rows, one for each multi-segment line.
I'm lost on the method to do the last piece. Mostly it relates about how to approach which piece first. Seems like a straightforward SQL, but I've tried a few different things, and it falls part each time for me.
Anyone have examples of something like this to start from?
The pertinent Mapfile fragment, I know this only color codes each individual segment at the moment. VEH_IDs are passed into the MapFile from CGI (vname=veh_id in DB):
DATA "the_line FROM (select the_line, vname, acqtime, trunc(random() * 4 + 1) rnum from loc) as foo USING unique vname using SRID=4326"
FILTER " vname in (%veh_id%) AND acqtime > '%time_idx1%' AND acqtime <'%time_idx2%' "
VALIDATION
'time_idx1' '.*'
'time_idx2' '.*'
'veh_id' '.*' ## veh_id='100','200','300' . . .
END
CLASSITEM "rnum"
CLASS ## Use the RNUM value to color code the line strings randomly.
STYLE
COLOR 255 0 0
WIDTH 5
END
EXPRESSION '1'
END
CLASS
STYLE
COLOR 0 255 0
WIDTH 5
END
EXPRESSION '2'
END
CLASS
STYLE
COLOR 0 0 255
WIDTH 5
END
EXPRESSION '3'
END
CLASS
STYLE
COLOR 255 255 0
WIDTH 5
END
EXPRESSION '4'
END
CLASS
NAME "Segments"
STYLE
COLOR 0 255 0
WIDTH 5
END
END
Thanks
Bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141202/99b15cbe/attachment.html>
