[mapserver-users] [mapserver-dev] need help with outputformat=kml for wfs
zach cruise
zachc1980 at gmail.com
Fri Dec 19 18:26:49 PST 2014
i got it. works with "DRIVER OGR/KML" (not "DRIVER KML").
On 12/19/14, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
> Ok, let's try this outside of WFS context. You should be able to do
> something like:
> /cgi-bin/mapserv?map=...&mode=map&mapext=...&map.imagetype=kml
> Does that work?
> Steve
> -----Original Message-----
> From: zach cruise [mailto:zachc1980 at gmail.com]
> Sent: Friday, December 19, 2014 9:27 AM
> To: Lime, Steve D (MNIT)
> Cc: mapserver-users; mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] need help with outputformat=kml for wfs
> yes
> On 12/18/14, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
>> Can you get at the layer GML without the output layer parameter?
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of zach
>> cruise
>> Sent: Thursday, December 18, 2014 9:18 AM
>> To: mapserver-users
>> Cc: mapserver-dev at lists.osgeo.org
>> Subject: [mapserver-dev] need help with outputformat=kml for wfs
>> using-
>> * MapServer version 6.4.0 ... OUTPUT=KML ... SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT ...
>> * httpd file-
>> <IfModule mime_module>
>> AddType application/vnd.google-earth.kml+xml .kml
>> </IfModule>
>> * map file-
>> MAP
>> IMAGETYPE kml
>> WEB
>> METADATA
>> "wfs_getfeature_formatlist" "kml"
>> END
>> END
>> OUTPUTFORMAT
>> NAME "kml"
>> DRIVER KML
>> MIMETYPE "application/vnd.google-earth.kml.xml"
>> IMAGEMODE RGB
>> IMAGEMODE FEATURE
>> EXTENSION "kml"
>> FORMATOPTION "ATTACHMENT=doc.kml"
>> END
>> LAYER
>> END
>> END
>> * url-
>> ../cgi-bin/mapserv?SERVICE=wfs&REQUEST=getfeature&TYPENAME=shoppinglis
>> t&VERSION=1.0.0&OUTPUTFORMAT=kml
>> (with or without "MODE=map")
>> but all i get is (no placemarks for points?)- <?xml version="1.0"
>> encoding="UTF-8"?> <kml xmlns="http://www.opengis.net/kml/2.2">
>> <Document>
>> <Style id="LayerFolder_check">
>> <ListStyle>
>> <listItemType>check</listItemType>
>> </ListStyle>
>> </Style>
>> <Style id="LayerFolder_checkHideChildren">
>> <ListStyle>
>> <listItemType>checkHideChildren</listItemType>
>> </ListStyle>
>> </Style>
>> <Style id="LayerFolder_checkOffOnly">
>> <ListStyle>
>> <listItemType>checkOffOnly</listItemType>
>> </ListStyle>
>> </Style>
>> <Style id="LayerFolder_radioFolder">
>> <ListStyle>
>> <listItemType>radioFolder</listItemType>
>> </ListStyle>
>> </Style>
>> <name>shoppingmap</name>
>> <Folder>
>> <name>shoppinglist</name>
>> <visibility>1</visibility>
>> <styleUrl>#LayerFolder_check</styleUrl>
>> </Folder>
>> </Document>
>> </kml>
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
