[mapserver-users] yum installation of mapserver 6.2.1-5 (fedora 20)
Blaise
bpicinbono at worldonline.fr
Fri Jul 4 09:31:02 PDT 2014
hi,
please Alessandro, reply to the list instead of private mailing;
it seems that in the mapserver packages of older Fedora versions, the
mapserv file was here: /usr/sbin/mapserv;
with Federa 20, the file is now: /usr/libexec/mapserver
(you can check it here:
http://www.rpmseek.com/rpm/mapserver-6.2.1-5.fc21.armv7hl.html?hl=com&cs=libfcgi.so.0:RE:0:0:0:0:0:11828979
and
http://www.rpmseek.com/rpm/mapserver-6.0.3-6.fc18.i686.html?hl=com&cs=libfcgi.so.0:RE:0:0:0:0:0:9928024
copy the /usr/libexec/mapserver file in /var/www/cgi-bin/ and rename it
mapserv and it should run fine;
regards
Blaise
On 07/04/2014 10:38 AM, Alessandro Mazzella wrote:
> Dear Blaise,
> Thank you for your answer. However no files within dir
> "/var/www/cgi-bin/" and no the "mapserv" file on whole my HD, while
> shp2img and legend are correctly into /usr/bin/ directory . As you
> requested this is the output of "yum info mapserver":
> [root at localhost amazzella]# yum info mapserver
> Loaded plugins: langpacks, refresh-packagekit
> Installed Packages
> Arch : x86_64
> Version : 6.2.1
> Release : 5.fc20
> Repo : installed
> From repo : fedora
> Summary : Environment for building spatially-enabled internet
> applications
> URL : http://www.mapserver.org
> License : BSD
> Description : Mapserver is an internet mapping program that converts
> GIS data to
> : map images in real time. With appropriate interface pages,
> : Mapserver can provide an interactive internet map based on
> : custom GIS data.
> Thanks again
> AM
> On 3 July 2014 19:01, Blaise <bpicinbono at worldonline.fr
> <mailto:bpicinbono at worldonline.fr>> wrote:
> hi,
> mapserv should be found in /var/www/cgi-bin/
> what is the output of:
> yum info mapserver
> On 07/03/2014 06:22 PM, Alessandro Mazzella wrote:
>> Hi all,
>> I'm trying to install mapserver 6.2.1-5 on my Fedora20 VM with
>> yum, but I'm reporting a crucial problem: yum installation
>> successfully ends, but there is no "mapserv" file on whole my
>> filesystem.
>> Any suggestion ?
>> Thanks all
>> AM
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Dott. Ing. Alessandro Mazzella, Ph.D.
> IGAG CNR - Istituto di Geologia Ambientale e Geoingegneria, Consiglio
> Nazionale delle Ricerche
> /IGAG CNR - Institute of Environmental Geology and Geoengineering,
> National Research Council of Italy/
> c/o DICAAR - Dipartimento di Ingegneria Civile, Ambientale e
> Achitettura, Università di Cagliari
> Piazza d'Armi, 19 - I-09123 Cagliari
> Ph.: +39 070 675 5564
> Fax : +39 070 675 5523
> Mobile: +39 349 4362827
> E-mail: amazzella at unica.it <mailto:amazzella at unica.it>
> E-mail: alessandromazzella at gmail.com <mailto:alessandromazzella at gmail.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140704/442703a5/attachment.html>
