[mapserver-users] mapcache issue2
thomas bonfort
thomas.bonfort at gmail.com
Mon Jul 7 01:50:35 PDT 2014
You're getting this message because the upstream WMS server isn't
returning an image given the getmap request that mapcache is sending
to it. The error message should contain a bit more info, or you can
manually replay the request mapcache has sent by looking into your
mapserver's access logs and copying the full request string. Possible
causes of such failure are an invalid mapserver url, an
unconfigured/wrong list of LAYERS=, an unsupported SRS, etc...
regards,
thomas
On 7 July 2014 01:26, Андрей Андреевич <treasurehunterf at mail.ru> wrote:
> Hello. I'm trying to setup mapserver with mapcache to getting local set of
> tiles(i'm use simple set of png files -> map file doesn't required, right?)
> available from here C:/test/wgs84 (On my PC), but didn't get success. I've
> read hundred pages of manuals, tutorials, forums etc, but didn't found
> anything usefull. Will you help me?
> I'm using Windows 7 x64. I was configure apache and mapcache, as has been
> written in manual mapserver.org/mapcache/install.html#windows-instructions :
> 1.LoadModule mapcache_module "C:/ms4w/Apache/cgi-bin/mod_mapcache.dll"
> 2.
> <IfModule mapcache_module>
> <Directory "C:/ms4w/apps/mapcache/">
> Order Allow,Deny
> Allow from all
> </Directory>
> MapCacheAlias /mapcache "C:/ms4w/apps/mapcache/mapcache.xml"
> </IfModule>
> identity of successful configure is:
> 1.in error.log
> [Fri Jul 04 16:38:57 2014] [notice] Apache/2.2.21 (Win32)
> mod-mapcache/0.5-dev configured -- resuming normal operations
> configuration of mapcache is not big (attached), and main point, is it
> configuration file correct?(I'm worry about <http> <url> entry)
> Seems everything are ready to start send request to get desired tiles from
> my local storage(through mapserver(macache)), right?
> I was sent request like a
> http://127.0.0.1/mapcache/wmts?service=WMTS&version=1.0.0&request=gettile&layer=test&style=default&tileMatrixSet=testgrid&tileMatrix=0&TileRow=0&TileCol=0&format=image/png
> and get error "wms request for tileset test returned an unsupported
> format:". Why wms(not wmts, i was sent wmts request) was answered to me? and
> what is specifically wrong?
> I was tried to get more information about error, end tried to sent
> getCapabilities request like a :
> http://127.0.0.1/mapcache/wmts?service=WMTS&request=getcapabilities&version=1.0.0
> and I was get xml file(attached "wmts.xml"). It's looks like correct, right?
> Finaly, i was not found answers to my questions, and tried to get source of
> mapcache. I was tried to build it with cmake 2.8.10.2 + msvc 2010
> Cmake was configure a solution correctly, but msvc 2010 didn't build it.
> I'm attaching screenshots with cmake successful configure log and visual
> studio error log.
> What I'm doing wrong? I'm don't understand it. Can you help me please?
> mapserver-users at lists.osgeo.org
