[mapserver-users] no oracle access with ogr
Dietmar Stolz
dietmar.stolz at freenet.de
Fri Jul 18 03:50:38 PDT 2014
Dear list,
I have a problem with the oracle access via ogr.
Beforehand: with orginfo and shp2img everthing works fine. I get my
geometries as well as images. Examples:
/orginfo --formats shows -> "OCI" (read/write)/
/ogrinfo -al oci:usr/pwd at gspp:table -geom=SUMMARY/
/shp2img -m test.map -o output.png -all_debug 5 -e 523600 5549800
581900 5639700 -l strom/
With mapserver via getmap request i get the following error:
/[Fri Jul 18 10:21:13 2014].50000
msOGRFileOpen(OCI:xxx/xxx at GSPP:TAALBF_NETZGEBIET).../
OGROPen(OCI:xxx/xxx at GSPP:TAALBF_NETZGEBIET)/
/[Fri Jul 18 10:21:13 2014].51000 msOGRFileOpen(): OGR error. Open
failed for OGR connection in layer `strom'. File not found or
unsupported format./
/[Fri Jul 18 10:21:13 2014].55000 msDrawMap(): Image handling error.
Failed to draw layer named 'strom'./
My mapfile (partial):
/ LAYER/
/ DEBUG 5/
/ NAME "strom"/
/ TYPE POLYGON/
/ CONNECTIONTYPE OGR/
/ CONNECTION "OCI:///:usr/pwd/@GSPP"/
/ DATA "TAALBF_NETZGEBIET"/
/ METADATA/
/ "ows_title" "xxx"/
/ "ows_abstract" "xxx"/
/ "ows_extent" "523600 5549800 581900 5639700"/
/ END/
/ CLASS/
/ STYLE/
/ OUTLINECOLOR 0 0 0/
/ COLOR 255 0 0/
/ WIDTH 2/
/ END/
/ END/
/ END/
I work on Windows Server 2012 Datacenter with Mapserver 6.4.1 and GDAL
1.11.0 (from release-1600-x64-gdal-1-11-mapserver-6-4).
I have also tested older versions. without success.
I set a lot of system variables:
set path=C:\Apps\Oracle.112.x64\bin;
set ORACLE_HOME=C:\Apps\Oracle.112.x64
set GDAL_DRIVER_PATH=D:\webgis\mapserver-6-4-1\bin\gdal\plugins
set GDAL_DATA=D:\Temp\mapserver-6-4-1\bin\gdal-data
set LD_LIBRARY_PATH=C:\Apps\Oracle.112.x64\lib;
set TNS_ADMIN=C:\Apps\Oracle.112.x64\network\ADMIN
set ORACLE_SID=GSPP
set ORACLE_BASE=C:\Apps\Oracle.112.x64
Why the mapserver gives me no bitmap?
Thanks a lot
Dietmar
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140718/f9c2c46e/attachment.html>
