[mapserver-users] WMS Client changes slightly BBOX
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Fri Jul 25 04:53:35 PDT 2014
This would be perfectly compatible with the difference on 1 pixel.
Thanks,
Peter
On 07/25/2014 12:32 AM, Lime, Steve D (MNIT) wrote:
> There’s a difference between the extent models used by MapServer and
> OGC. The WMS code adjusts for that difference so the input extent will
> definitely see adjustment to account for that. OGC uses the UL corner
> of the UL pixel and the LR corner of the LR pixel. MapServer uses
> pixel centers consistently. Do your scale computations account for
> this difference?
> Steve
> *From:*mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Peter
> Hopfgartner
> *Sent:* Thursday, July 24, 2014 7:20 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] WMS Client changes slightly BBOX
> Hi Worth,
> thanks for your quick reply. Anyway, the ratio of the extent and of
> the image seem to match al least up to 10 digits. Playing with the
> numbers, the error is in the same order of magnitude as if I change
> image size by one pixel. I would guess, that there is a "off by 1"
> error somewhere in the MapServer code.
> Regards,
> Peter
> On 07/24/2014 01:30 PM, Worth Lutz wrote:
> Peter,
> I have found that if the map size (width and height in pixels)
> aspect ratio does not exactly match the map extents (map units)
> aspect ratio the map extents are adjusted.
> I'm working with MapScript and to get exact scale pdf map I have
> to set map size first and then extent and then scale to get good
> results.
> I hope this helps.
> *Worth Lutz*
> On 07/24/2014 06:49 AM, Peter Hopfgartner wrote:
> I'm generating dynamically Map Object, with with a certain
> extent, in the concrete example
> 629396.05065523,4984079.9894638,655192.92565523,5019084.3644638
> In generated Map object uses the WMS client functionality to
> call WMS services. Anyway, the BBOX get's slightly changed, so
> that the original scale of 1:100000 gets changed to approx
> 1:100103, since it calls the WMS services with
> 629382.807906257,4984062.02007212,655206.168404203,5019102.33385548
> as can be taken from the web server log files:
> mmm.mmm.mmm.mmm - - [24/Jul/2014:12:25:58 +0200] "GET
> /author/services/ows.php?PROJECT=ancitel&MAP=catasto_reti&LANG=xw&OGSTAT=ot3cp0i7qmph4guuof75702m70&RESOLUTION=96&LAYERS=dtm,uso_lombardia,strade_lombardia,g_limiti_amministrativi,g_label,g_0707,g_0704&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/png%3B+mode%3D8bit&STYLES=,,,,,,&HEIGHT=1323&VERSION=1.1.1&SRS=EPSG:32632&WIDTH=975&BBOX=629382.807906257,4984062.02007212,655206.168404203,5019102.33385548&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
> HTTP/1.1" 200 678803 "-" "MapServer/6.4.1 libcurl/7.19.7"
> This change in scale is beyound te axpected tolerance in this
> particular use case, where technical data must be plotted in a
> PDF file.
> Any help is appreciated. Obvioulsly, I can fetch the WMS
> services in my code and overlay them "by hand". Anyway, for a
> couple of reasons this was the preferred approach.
> Regards,
> Peter
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
Peter Hopfgartner
R3 GIS Srl - GmbH
web : http://www.r3-gis.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140725/e0885f19/attachment.html>
