[mapserver-users] Problems with getting geojson running as WFS response
Jacob Mendt
jacobmendt at googlemail.com
Mon Jul 28 01:30:09 PDT 2014
Hey Jukka,
i set up a ticket here: https://github.com/mapserver/mapserver/issues/4966
Hope that helps.
Kind regards,
JM
Von: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Rahkonen
Jukka (Tike)
Gesendet: Samstag, 26. Juli 2014 09:25
An: mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] Problems with getting geojson running as WFS
response
I would say that if your service is advertising geojson as a supported WFS
outputformat in GetCapabilities it should also support all standard WFS
requests and parameters and MaxFeatures is such an important parameter that
at least that should work for all outputformats. I suggest you to file a bug
into github https://github.com/mapserver. The developers woud like to get
also a repeatable test case with a small shapefile and mapfile.
-Jukka Rahkonen-
_____
Jacob Mendt wrote:
Hi List,
i did some further testing and meet some unexpecting behavior. If I doesn't
use "MAXFEATURES" in my WFS-Request I get back a GeoJSON Response. Is that
wanted behavior or do I miss something?
Kind regards,
JM
Von: Jacob Mendt [mailto:jacobmendt at googlemail.com]
Gesendet: Dienstag, 22. Juli 2014 09:51
An: 'Rahkonen Jukka (Tike)'; mapserver-users at lists.osgeo.org
Betreff: AW: [mapserver-users] Problems with getting geojson running as WFS
response
Hi Jukka,
yes i tried this. But the behavior stays the same.
JM
Von: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen at mmmtike.fi]
Gesendet: Dienstag, 22. Juli 2014 09:30
An: Jacob Mendt; <mailto:mapserver-users at lists.osgeo.org>
response
Have you tried to request geojson with its MIMETYPE as
&format=application/json; subtype=geojson ?
-Jukka Rahkonen-
_____
Jacob Mendt wrote:
> Hey List,
> i am right now trying to bring get my Mapserver (Version 6.0.0) WFS
running with GeoJSON. But I always get back an empty response. I tried
several approaches and my WFS runs with a GML response. So maybe somebody
could give me hint. Here is my mapfile:
MAP
PROJECTION
"init=epsg:4314"
END
EXTENT 5.83333301544189 47.2000007629395 23.0000019073486 56
# OUTPUTFORMAT
# NAME "geojson"
# DRIVER "OGR/GEOJSON"
# MIMETYPE "application/json; subtype=geojson"
# FORMATOPTION "STORAGE=stream"
# FORMATOPTION "FORM=SIMPLE"
# END
OUTPUTFORMAT
NAME "geojson"
DRIVER "TEMPLATE"
FORMATOPTION "FILE=/home/test/messtischblatt.js"
END
WEB
METADATA
"wfs_srs" "epsg:900913 epsg:4314 EPSG:3857 EPSG:4326
EPSG:3978"
"wfs_getfeature_formatlist" "geojson"
END
END # WEB
# geojson layer
LAYER
TEMPLATE "messtischblatt.js"
STATUS ON
NAME "test"
TYPE POLYGON
EXTENT 649304.652862922 6090078.57976033 2559975.30438738
7538210.86255982
DATA "boundingbox from (SELECT * FROM layer ORDER BY titel, time) as foo
using unique id using srid=900913"
CONNECTIONTYPE postgis
CONNECTION "dbname=*** user=*** password=*** host=*** "
#DATA "messtischblatt"
#CONNECTIONTYPE OGR
#CONNECTION "PG: dbname=*** user=*** password=*** host=***"
PROJECTION
"init=epsg:900913"
END
METADATA
"wfs_title" "Test WFS"
"wfs_srs" "EPSG:4326 EPSG:4314 EPSG:900913 "
"wfs_enable_request" "*"
END
END
END # MAP# Tile Index
I test it with a couple of approaches. It tried both Outputformats and both
ways of defining a postgis data source. But in any case I get back an empty
response. With the template approach I used the following template:
[resultset layer=test]
"type": "FeatureCollection",
"features": [
[feature trimlast=","]
"type": "Feature",
"id": "[id]",
[/feature]
[/resultset]
I run my mapserver also with DEBUG level 5. I got the following log output:
[Mon Jul 21 18:10:21 2014].528584 msFreeMap(): freeing map at 0x19447b0.
[Mon Jul 21 18:10:22 2014].387718 CGI Request 1 on process 4362
[Mon Jul 21 18:10:22 2014].521952 mapserv request processing time (msLoadMap
not incl.): 0.134s
My test request is:
http://localhost/cgi-bin/mtbows?map=./test.map
<http://localhost/cgi-bin/mtbows?map=./test.map&SERVICE=WFS&VERSION=1.0.0&RE
QUEST=getfeature&TYPENAME=test&MAXFEATURES=100&srsname=EPSG:900913&bbox=1518
929.826549386,6766016.954331277,2693002.5808462612,7384239.639015725&outputf
ormat=geojson>
&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=test&MAXFEATURES=100&
srsname=EPSG:900913&bbox=1518929.826549386,6766016.954331277,2693002.5808462
612,7384239.639015725&outputformat=geojson
Could somebody give me an advice?
Kind regards,
JM
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140728/9df6e298/attachment-0001.html>
