[mapserver-users] New to Mapserver
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jul 31 13:20:42 PDT 2014
On 2014-07-31 5:18 PM, Jeff McKenna wrote:
> Hi Tim,
> Regarding the msLoadMap error, I would:
> - try to make sure you can generate a valid map image from your mapfile
> using the shp2img commandline tool (included in MS4W)
> - then once you have a map image, then try to call mapserv.exe in a
> browser with &MODE=browse&TEMPLATE=openlayers
You'll also need the &MAP= parameter also, that is the path to your
mapfile. But as Steve said, maybe better to start with the tutorial :)
> - then if no errors you can configure your mapfile to serve WMS and
> execute a GetCapabilities request in a browser.
> -jeff
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
