[mapserver-users] New to Mapserver
Rolling Leaf Support
support at rollingleaf.com
Thu Jul 31 13:25:06 PDT 2014
Thanks for the quick responses! I had read through the tutorial before when
I was trying to initially get Mapserver up and running but I will go
through it much greater detail now that I have a better understanding of
Mapserver as a whole.
On Thu, Jul 31, 2014 at 4:20 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com
> wrote:
> On 2014-07-31 5:18 PM, Jeff McKenna wrote:
>> Hi Tim,
>> Regarding the msLoadMap error, I would:
>> - try to make sure you can generate a valid map image from your mapfile
>> using the shp2img commandline tool (included in MS4W)
>> - then once you have a map image, then try to call mapserv.exe in a
>> browser with &MODE=browse&TEMPLATE=openlayers
> You'll also need the &MAP= parameter also, that is the path to your
> mapfile. But as Steve said, maybe better to start with the tutorial :)
>> - then if no errors you can configure your mapfile to serve WMS and
>> execute a GetCapabilities request in a browser.
>> -jeff
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
Rolling Leaf Inc.
[E] : support at rollingleaf.com <jochs at rollingleaf.com>
[V] : *(762) 233-8826*
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140731/264e7330/attachment.html>
