[mapserver-users] What is the default coordinate system used in MapServer (if no projection is defined)?
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Mon Jun 2 15:40:24 PDT 2014
All,
So I was trying to just display some data without a coordinate system assigned. And I ended up eventually getting a LAT/LON (out of range) error. Once I set the projection in the MAP block to something resembling a XY projection, all was well.
I suspect that LAT/LON is the default? Is there a way to do something other than what I did to use simple Cartesian coordinates?
Bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140602/c9c12719/attachment.html>
